Kentsfield 6700 is supposed to deput at $999.00 on November 13th according to the info I hear. If it does AND if it's as good as the 6700ES's we've seen then it is the way to go for output per physical space a system takes and thats an issue for Victor, at least it used to be.
They also generate a ton of heat that has to be dealt with.
I'd still go with the 6600's and the bad axe for output/cost
