It looks like you have to leave 1 core to help with the GPU folding client, so you can run CPU client and 1 GPU.
Asus P9X79 Pro | i7 3820 @ 4.875GHz | 4x4GB Corsair DDR3-1600| 3x 6970 Lightnings watercooled| Corsair 1200W PSU | Mountain Mods Ascension case |
Any early indications on how much extra score is achieved, is it anything near the 40 times faster?
The calculations that it does are supposedly 20x faster or more, but the points are different. With an X1900XT the points end up being about 400/day.Originally Posted by v0dka
Mine did 11 early ends overnight & then picked up a good WU about 3am , & was 25 frames in by 8am. I've stopped the client until I get back from work so I can pick through the log file. The errors looked like this:
[22:30:38] Project: 2722 (Run 1, Clone 68, Gen 0)
[22:30:38]
[22:30:38] Assembly optimizations on if available.
[22:30:38] Entering M.D.
[22:30:50] Completed 0
[22:30:50] Starting GUI Server
[22:42:07] Completed 1
[22:53:24] Completed 2
[22:53:35] mdrun_gpu returned 114
[22:53:35]
[22:53:35] Folding@home Core Shutdown: EARLY_UNIT_END
[22:53:38] CoreStatus = 72 (114)
[22:53:38] Sending work to server
[22:53:38] - Error: Could not get length of results file work/wuresults_02.dat
[22:53:38] - Error: Could not read unit 02 file. Removing from queue.
I'll try the 6.5 drivers later, since I'm on the 6.10's here at the moment.
Will be nice when I can throw the GX2 @ this...
ID love to run 2 instances console vid, and 2 conroe core GUI, thatd be killer for WCG'rs
Join the XS WCG team and do your part to help save the world..
^^^Click here to start folding for the soon to be number one team in the world..^^^
Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
"A computer beat me in chess, but it was no match when it came to kickboxing"
-Emo Philips
Thanks for the help. I will give it a try.Originally Posted by Atomicpineapple
cheers
hoax
My 3 cents: cooling issues if your seeing them: It's fall now and most people have taken out any window fans they have. A 20 inch window fan set beside a full tower on low is an amazing cooler( side panel off of course)
That will push a 100 times the air in and out of that case and never give the vid card a chance to overheat.
ok, you can pick this old fart apart now but it does work well and the noise level is very low. Also a 20" window fan takes crap for elec on low speed and thats all you need.
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
OK I started this last night about 12 or so. Got one EUE but then it has been working fine since. Completed 71 steps at about 8 min per step. GPU temps have stayed around 73*C which is alot lower than I expected (I was expecting full load temps of 90*C like after gaming or something).
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
I've left mine running since early this morning with the beta 6.10s and latest DX build, i get roughly 73oC on GPU as well. So its not pounding the graphics card as far as I can tell... Still waiting for some results, post back later
FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
eXceed TJ07 worklog/build
If an XT gets around 400 ppd, would a GT get around 300?
A wolf in wolves clothing.
DragonOrta, I don't think anyone really knows yet, too early to tell. But I'm no authority on this so I very well may be wrong.
Darnit though, I think the GPU client has stalled on me It has been consistently 8 minutes between steps but now it has been saying "Completed 85" for the past 20 minutes However, the CPU and GPU temps are still up there
Ideas?
I guess I'll just wait for a week or so to see which GPU is the best cruncher for the money.
It's not stuck. According to the Pande group, the calculations are much bigger than the CPU calculations so it just takes longer. It just happens to be at that 85 mark.Originally Posted by SparkyJJO
Got unstuck yet Sparky or has it early ended on you? From what I read not many people are having much luck with the 2722wu/Cat 6.10 combination, but I'll let mine run again tonight & see what happens to it regardless.
Actually yes it got unstuck. Apparently it kept going but it didn't update the progress report. At the 85 mark I am assuming there were 15 marks left, and at 8 minutes per mark that would have been 2 hours left. Well two hours after the 85 mark appeared and stuck there it suddenly said "complete" and uploaded the finished results to stanford and got another WU. My guess is it just forgot to update
Currently at the 25 mark of the next WU.
As it stands I think that as long as it keeps working fine then I don't mind it running instead of the CPU client. For one thing I get more PPD with it (took about 2-3 days for the average 400-ish point WU to complete that I keep getting)
It seems 6.5's, no service and text client are the perfect combo for it just working, had no problems what-so-ever so far.
Workstation:
3960X | 32GB G.Skill 2133 | Asus Rampage IV Extreme
3*EVGA GTX580 HC2 3GB | 3*Dell U3011
4*Crucial M4 256GB R0 | 6*3TB WD Green R6
Areca 1680ix-24 + 4GB | 2*Pioneer BDR-205 | Enermax Plat 1500W
Internal W/C | PC-P80 | G19 | G700 | G27
Destop Audio:
Squeezebox Duet | Beresford TC-7520 Caiman modded | NAD M3 | MA RX8 | HD650 | ATH-ES7
Man Cave:
PT-AT5000E | TXP65VT30 | PR-SC5509 | PA-MC5500 | MA GX300*2, GXFX*4, GXC350 | 2*BK Monolith+
Gaming on the go:
Alienware M18x
i7 2920XM | 16GB DDR3 1600
2*6990 | WLED 1080P
2*Crucial M4 256GB | BD-RW
BT 375 | Intel 6300 | 330W PSU
2011 Audi R8 V10 Ibis White ABT Tuned - 600HP
Yeah I'm using the 6.5's and text console and it has only had one EUE which I believe was caused by the 6.10 betas (started using those first)
For reference, 2.5 days for one core of my E6400 on a 2124/396pts.Originally Posted by SparkyJJO
FaHmon-Benchmarks, indicate this:
Min. Time / Frame : 28mn 44s - 198.46 ppd
Avg. Time / Frame : 29mn 13s - 195.18 ppd
hmm maybe I am not thinking of PPD right, hmm.
I have no idea how the ppd is calculated or relates. Anyone?Originally Posted by SparkyJJO
Guys try deleting the fcore 10 from the folding folder. The cores are being improved all the time. When the gpu client detects no core it will download the latest version.
Regards
John.
"Thermodynamics is a funny subject. The first time you go through it, you don't understand it at all. The second time you go through it, you think you understand it, except for one or two points. The third time you go through it, you know you don't understand it, but by that time you are so used to that subject, it doesn't bother you anymore".
OK I believe I'll do that after this WU is complete (just passed the 31 mark). Unless I won't lose my progress if I delete it now?
good advice. Anyone tried Crossfired X1900XTs yet?
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
If it aint broke dont fix it Wait until your wu completes, then stop the client delete core and restart.Originally Posted by SparkyJJO
Regards
John.
man this wu is slow been running over 24 hours now and im at 31. something sounds wrong...
