I ended up getting a Asus P5B DLX and it seems to run well.
Looks like my E6300 does around 3200MHz with stock cooling. 7x458.
OPP
OPP
Hey opp you got a nice board there, thats what i use. If you still think memory is holding you back chipset voltage will help memory go alot further.
My e6300 did 3.6 stock cooler. I had an FSB wall after that. I ended up running 3.5ghz with low volts on a big typhoon.
I don't think it was a FSB problem on this test, I could be wrong. I'll be upgrading the cooling later this week, first test will be the Typhoon, then going to water, chilled water, then Phase. I guess I will really find out if I have a FSB problem as I start cooling the chip better.Originally Posted by Revv23
I like the board, much nicer then the Asus P5W DH that I started out with.
OPP
well here's mine
stable 24/7
By the way, what video card are you using? I'm starting to wonder if the 7950 card I have could hold me back.Originally Posted by Revv23
OPP
Originally Posted by OPPAINTER
I did it with a geforce 6200 turbocache....my 1900xtx is pending RMA.
I hear that 7950's act up on this motherboard, and the fix is simple. set the PCI-E frequency to 95. I have no experience with it but it could be worth a shot.
The P5W is a nice board too but the 975 chipset simply cant hit the kind of FSB that the 965 can.
Good luck OPP.
