What is the common max overclock for the Core2 Duo E6300 chip?
I'm talking stock cooling, straight out of the box?
Thanks.
OPP
Thanks.
OPP
Heres...Probly not maxed yet
Edit: With TT Big Typhoon.
Nice clock, I saw that thread
I'm testing a 6300 at work with an Asus P5W DH.
The 6300 seems to want to do more but it is stuck on stupid around 430x7 1:1. I get memory problems going past 430. Is the Asus just the problem? Looks like Dumos Gigabyte does 500 fsb with ease.
OPP
Same here
This is rig for work with 6300 and Giga S3 (with new C2 chipset)...Got it from CompUS..
Would you recommend the board? What don't you like about it?Originally Posted by Dumo
OPP
Yes, for the price from Newegg etc....Not from CompUS.Originally Posted by OPPAINTER
Its ok for daily rig.
If I go over to Frys and pick up the S3, what are the chances I will get the C2 chipset? If it's another chipset, will the board suck?Originally Posted by Dumo
http://shop2.outpost.com/product/492...H:MAIN_RSLT_PG
OPP
Heres C1...http://www.xtremesystems.org/forums/...highlight=dumo
Heres C2 ser#0636...Came with F3 bios and I flashed to F5....
Thanks, this helps a lot
So I need to find a box that has the 0636 in the serial#.
Then I need to flash to F5.
Correct?
OPP
YesOriginally Posted by OPPAINTER
OK then, the hunt is on.
I'm out of here
Thanks,
OPP
Where can I get the board with the S3, DS3, with the C2?
Alex
Originally Posted by AgonxOC
Good question.
I just bought an S3 at PCClub, only to find out it was a C1 version.
OPP
Christ my E6600 isn't capable of those clocks
t
My E6300 with Asus P5W DH:
http://kotisivu.dnainternet.net/bull..._3m34.125s.png
My e6300 with watercooling on ds3 c1.
With stock boxed cooler did 3.5 1.35v but temps were to high to my liking
Might need some off your experienced people to help me max it out when I get phase
Edit: small difrence in mhz due to ram crapping out quicker then cpu.
Dayum Dumo!! Nice job, specially on stock air cool!Originally Posted by Dumo
can you bost your BIOS settings? (Vcore, Vdimm, NB, SB, etc, etc).
thanks!
geezus...all you guys getting some nice numbers!Originally Posted by BulldogPO
what was your BIOS settings? Also, what did you use for your memory? 1:1 or 4:5? did you use ddr2-800 or ddr2-1000 or what?
@dumo I had an S3 0636 and with the F5 bios i can't pass 440 fsb....i can boot at 440...but no go after..
When Mercedes brought their C111 to Talledega years ago and blew away the closed course record did it count? Yes..
That was a "factory" car and a "one of" that no one could buy and was never sold.
Records are records and that is a fact so get over it.
My memory was 3:4
my S3 does 500FSB with +.2NB +.1FSB, increasing voltage i made it to 570FSB. stability issues due to passive cooling and crappy active cpu cooling
STARSCREAM
3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
MEGATRON
3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
Corsair AX650 | Corsair H80i
did you use the following?Originally Posted by BulldogPO
PCI f = 100
Vdimm = 2.1
Vcore = 1.48
FSB core = 1.4
NB core = 1.55
SB core = 1.7
if not, could you post what you used? that's what I'm shooting for (3.1ghz) and I dont wanna mess up a 3rd board
The Vcore and the Vdimm , depends to your stuff..!
Try PCI-F over 115 to achieve bigger FSB!
@itznfb your mobo has the c2?
I have similar stuff to Bulldog: P5B deluxe wifi, 2x1gb Crucial Baliistix PC6400, Scythe Infinity + fan, e6300, etc.
that's Why I asked, to compare my last settings (before the board went bad) to his and see where the differences lie.
i'm honestly not sure, i'll check when i get homeOriginally Posted by GoriLLakoS
STARSCREAM
MEGATRON
