+ Reply to Thread
Results 1 to 15 of 15
Thread: Does fanspeed effect stability?
    Xtreme Addict KoHaN69's Avatar
    Nov 2004
    0
    This question I was pondering about some time:
    Fan's use voltage, does that voltage used by the fan effect the other voltages on the card in any way?
    So does turning fan off or putting it to 100% make a difference if one is running on water?
    Member Holst's Avatar
    Dec 2002
    Leics UK
    0
    Not unless your power supply is total junk.
    Or the fan is absolutely massive and sucks LOADS of power.
    In your system the power used by the fan wont make any difference at all.
    Obviously temperatures will affect things.
    Nov 2004
    0
    So if the fan isn't even plugged in, there is NO difference, right?
    Dec 2002
    Leics UK
    0
    Why are you asking?
    Some motherboards and graphics cards wont like it if a fan isnt plugged in to the CPU / GPU and they wont work..
    But as for voltage changes there will be no difference at all.
    Nov 2004
    0
    For example on water (fan off), my x1800 gto's core was stable at 1.225v, but on air (80-100% fanspeed) it is only stable at 1.25v.
    So it's either the fanspeed or the +20C degree increase that require more volts
    Dec 2002
    Leics UK
    0
    Its the +20*c
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    the temps are the reason, not the fanspeed. Heck I wish it was true though, higher OC due to fan speed, that would rock
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    I am Xtreme Eastcoasthandle's Avatar
    Jul 2005
    0
    BUT is it worth it to buy ramsinks? I am having a hard time getting them to remain adhesive to the ram. They fall off do to some level of oil on the ram sinks that I can't get off yet.
    Any suggestions?
    Xtreme CCIE Serra's Avatar
    Dec 2004
    St. Louis, MO
    0
    Quote Originally Posted by Eastcoasthandle
    Any suggestions?
    The very best way to mount ramsinks is to put a small dab of AS5 (or comparable) TIM in the center (VERY small dab) and put small dabs of superglue on each corner, then just press it on for a minute or two. You'll get the best thermal transfer possible (significantly better than any thermal tape solution), and it pops off relatively easily with just a razer. Some people complain about doing this because they feel afraid that they won't be able to get it off, but I have never yet heard anyone who did this complain that they damaged a component during removal or were not able to get them off.
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
    c[_] STEvil's Avatar
    Nov 2002
    Alberta, Canada
    19
    Fans can, but thats really more related to the RFI sensitivity of the components your system is built from. Usually not really an issue with the massive amounts of RFI given off by the CPU, NB/SB, Video Card, etc..
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Nov 2004
    0
    Conclusion:
    fan voltage and gpu/mem voltage are on different 'mini rails (?)'
    Xtreme Cruncher [XC] MarioMaster's Avatar
    Feb 2006
    Emmaus, PA, US
    0
    Any suggestions?
    i used alcohol prep pads to clean the ram chips on my 6600gt before i stuck on the ramsinks, and none have ever fallen off, i've even restuck some several times and they are still sticky
    |Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
    (12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
    (12:16:19 AM) OC3D NoL: RAWRRRR
    Nov 2004
    0
    I just use superglue+arctic silver under the sticky thermal pad - this way if I mess up to take it off I just rip the thermal pad, not the ram off the card.
    Nov 2002
    Alberta, Canada
    19
    Quote Originally Posted by KoHaN69
    Conclusion:
    Some do, some dont. Sometimes it helps, sometimes it doesnt.
    Feb 2005
    0
    CLEAR YOUR PM BOX... I CAN'T SEND YOU ANY PMs, and you're not on AIM.
    ASUS Crosshair V *Water* | FX-8150 Enzotech Sapphire CPU block | 8GB Mushkin 2133 | 6970 2GB | 240GB OCZ Vertex 3 | SB X-Fi Elite Pro | Corsair 520W Modular | 3x 26" Asus VW266H Eyefinity 5760x1200 | DDC pump with petra top @ 18w, Thermochill HE 120.3 w/ 3x120x38mm Deltas 152cfm on controller |
    My Heatware (1000+ flawless)
+ Reply to Thread
