XIP - can sit on his hair
AX7 v PAL8045
Does anyone know of any linkage for comparisons between the Thermaltake AX7 & the AlphaPAL8045?? I use the 8045 at the mo and am wondering if I'd benefit much from moving over to AX7 or not....
E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
I used the 8045 and switched to the AX7 temps dropped 4c under load.
Hmmm.... looks like it is marginally better by 2-5 degrees... looks like I may have to find one soon then....
cheers guys!!
Another good point is size the 8045 has to be modded to fit quite a few mobo. The AX7 does not.
www.overclockers.com also has reviews of both heatsinks. u'll have to compare them urself tho
And you don't have to pull your mobo (or some folks make a cut out in the mounting plate) to take the AX7 off.
8045 has the bolts, and AX-7 (correct me if im wrong) uses all the lugs on the socket.
- You may not post replies
- You may not edit your posts
Forum Rules
