Results 1 to 7 of 7
Thread: Sierpinski/Riesel Base 5 Project
    Mar 2005
    "New" math project available with teams and stats.
    The goal is to look for the lowest Sierpinski and Riesel numbers in base 5.
    Here's a quote:
    he lowest even Reisel number is mooted to be 346802 and the lowest even Sierpinski 159986. That is to say 346802.5^n-1 is always composite for every n, and 159986.5^n+1 is similarly endowed.
    The Sierpinskis look the easiest to look at. We have to show there is a prime for every even k (in the power series k.5^n+1) less than k=159986 and I have checked so far up to n=18468 for all of the remaining values of k shown below. All other values of k have a prime at less than n=18468
    Robert Smith
    Stats are available here (thanks Lars)
    http://www.sr5.psp-project.de/
    Sieve - Clients (windows, linux)
    http://geocities.com/g_w_reynolds/sr5sieve/
    (always look for the latest version)
    LLRNET- Client (windows and linux)
    http://base5.greenbank.org/
    Project Forum
    http://www.mersenneforum.org/forumdisplay.php?f=54
    How to join or create a team?
    Just post here.
    How to run the LLRNET client?
    http://www.mersenneforum.org/showthread.php?t=6270
    Here you might find a bunch of primes. P4 only or fast AMD64.
    How to run the sieve client?
    Well, go here and reserve a sieve range. Then download the dat file from one of the following links:
    or
    http://home.wanadoo.nl/michafleuren/...sierpinski.htm
    Create a sr5work.txt and to sieve the range 50 billion to 55 billion (i.e. 50e9 to 55e9), you add a single line in sr5work.txt like this
    50,55
    Then start the client like this:
    start /min /low sr5sieve.exe
    Cheers,
    Carlos
    Free-DC Mercenaries member
    Mar 2005
    Since yesterday a new prime was found: 31342*5^102551-1 is prime!
    Bunch there to be found (298), will XS join the hunting? At this level a number is tested within 13 min on an AMD 64 3000+.
    Cheers,
    Carlos
    Mar 2005
    Since my last post a few primes have been found. No one here wants to join the fun?
    Carlos
    Mar 2005
    Hi all,
    Everyone is invited to make a 24 hr run on PRP Riesel testing starting on 20/10/2006 at 9pm (Zulu time).
    Free-DC members participating:
    Helix
    Free-DC Mercenaries
    tnerual
    edorajh
    Last time we did one Helix found a prime!!!!
    Carlos
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    Thanks for the invite Carlos,
    unfortunately XS Collegiate Mafia will not be particiapting in this hunt, the issue of registering a spectrum of numbers kind of makes this project difficult for me to stomach.
    Thank you for your most gracious invite and Best of Luck in your hunt for Primes
    Mar 2005
    The project really needs a boost on PRP testing.
    Please help by running the LLRNET client. Thanks.
    Carlos
    Mar 2005
    At least 6 primes have been found since my last post, I even found one!!!!
    Carlos
