AsRock ConroeXFire-eSATA2 motherboard Bios/Ram volts settings issue
So far, this board works good. I have it with a E6600, 2 sticks of 1 gig corsair (800) and a 7950. But with all the talk about high end ram on some boards causing issues due to volt settings, I wanted to check with you all and see if this was an issue, or sounded like one to you. When I go into BIOS to raise the volts to 1.9, it will not let me do it. All I can do is, see what the volts are at, which is 1.5, and set it to normal, or high. I didnt set it to high yet, because im not sure what that would do. Does anyone know if I should just update the bios to maybe get a better volts setting out of it? one that might allow me to set it to 1.9, or just set the current bios to high for the ram?
- You may not post replies
- You may not edit your posts
Forum Rules
