Results 1 to 3 of 3
Thread: Need advice on choosing RAM
    Sep 2006
    brazil
    Hello all,
    I am upgrading my current pc and I am trying to pick the best memory for the job, but I am having a hard time understanding all the different specs, and trying to figure out whats more important when picking from all the countless options out there.
    I see on the sticky that you guys recommend the CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit for people with extreme gaming systems in mind.
    Are there better (faster, lower lattency) modules I can get that would give greater performance with my motherboard? The PC will be mostly used for gaming. The motherboard and the processor will be:
    Asus P5W64 WS Professional
    Core 2 Extreme X6800 Dual Core Processor 2.93ghz
    I would prefer if the ram has great overclocking possibilities.
    any advice will be really appreciated
    best regards,
    hoax
    Nov 2005
    The Netherlands
    My advice - look for Corsair 6400C3 or 8000UL kits or buy some pre-tested DDR2 here @ XS
    Sep 2006
    brazil
    TaPaKaH,
    Thanks for the reply. I will try to find the ones you suggested.
    Sadly I cant place the order on XS.. I have to buy it in the same place I am getting the rest of the parts..but I wish I could..
    cheers
    hoax
