Results 1 to 19 of 19
Thread: Mushkin 2GB XP2-8000 Redline Test Report
    Apr 2005
    Calgary, AB
    Mushkin 2GB XP2-8000 Redline Test Results
    Hey guys, this is still a work in progress so keep an eye for updates.
    This RAM has been around a while but I havent saw a whole lot of tests for it for some reason. This stuff uses highly sought after D9GMH B6-3 chips and in my testing proves to be some of the top clockers currently on the market.
    That being said, here is your Mushkin XP2-8000 Redline (part 996525) test report.
    First I’ll start with a few words on the test platform and photos of the RAM and board. I’m using an E6400 Allendale setup with a s965p DQ6. The XP2-8000 usually has the red spreaders like other Redline, but this set got the black. I like the black better personally.
    Test bed
    Gigabyte GA-965P-DQ6 (unmodded)
    E6400
    MSI GeForce 7800GTX @ stock
    Mushkin XP-650
    Windows XP, untweaked
    CPU Cooling - Custom H20 and stock cooler on the NB
    Testing methodology:
    I wanted to test this mem with a stock DQ6 to show the potential without volt mods. Vdimm on this board goes to 2.37v set in the BIOS, higher than that the board will not boot and vmod is necessary. I plan of doing the vdimm mod soon, when I get some time and will post tests with more volts.
    I did a cpu-z validation in most cases, check the validation # on the RAM speed CPU-Z tab if you enjoy checking that type of stuff.
    Benches used:
    3dmark 2001 and 2006
    Super PI v1.5 (two instances)
    Orthos
    Sandra 07
    Tools:
    MemSet
    EasyTune 5
    CoreTemp
    Most of the tests are divided by voltage and timings, basically I tested 4-4-3, 3-4-3, and 3-3-3 at 2.3 and 2.37v. For my cas3 tests, I set cas3 in the BIOS and memset, sandra and cpuz all confirm cas3. People been saying cas3 is sometimes screwy, maybe it is who knows. However, I can run 3-4-3 @ 550Mhz no problem and 3-4-3 is slower running dual 32M but its faster running single 32M, so it might be working but I cant tell for sure
    Now for some test results..
    MB Reviewer for HWC
    Team OCX Bench Team
    Apr 2005
    Calgary, AB
    3-3-3 – 2.3v (bios) – 410 Mhz
    Dual 32M
    3DMark 2001 and 2006
    Sandra
    Orthos
    3-3-3 – 2.37v (bios) – 422Mhz
    Dual 32M
    Orthos
    3-4-3 – 2.30v (bios) – 535Mhz
    Dual 32M
    3DMark 2006
    Dual P95
    3-4-3 – 2.37v (bios) – 550Mhz
    Dual 32M
    3DMark 2001 & 2006
    Sandra 07
    Orthos
    MB Reviewer for HWC
    Team OCX Bench Team
    Apr 2005
    Calgary, AB
    4-4-3 – 2.30v (bios) – 538Mhz
    Dual 32M
    3DMark 2001 & 2006
    4-4-3 – 2.37v (bios) – 553Mhz
    Dual 32M
    3DMark 2001 & 2006
    4-5-4 – 2.30v (bios) – xxxMhz
    Testing in progress
    MB Reviewer for HWC
    Team OCX Bench Team
    Apr 2005
    Calgary, AB
    Overclocking Summary:
    2.3v
    3-3-3 - 410Mhz
    3-4-3 - 535Mhz*
    4-4-3 - 538Mhz
    2.37v
    3-3-3 - 422Mhz
    3-4-3 - 550Mhz*
    4-4-3 - 553Mhz
    *Unable to confirm that cas3 working properly, investigating further now.
    MB Reviewer for HWC
    Team OCX Bench Team
    Jan 2006
    France
    I think that your 3-4-3-12 is a 4-4-3-12.
    Never seen suck resultas at 2.4V...
    If you make 550MHz 3-4-3-x, you can easily do more than 600MHz 4-4-3-x.
    Despite my remark, your test is very clean
    Apr 2005
    Calgary, AB
    Yeah you are probably right, I figured that when 3-4-3 would clock so well. No idea how I can use "real" cas3 though..
    MB Reviewer for HWC
    Team OCX Bench Team
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Unfortunatly Gigabyte 965 boards are among the worst there is for reviewing ram with, cause there are numerous ways to get very misleading results.
    with all that we seen from the Gigabyte 965 boards, we put a self imposed ban on using them in future reviews on the frontpage to avoid any possible misleading info that can come up in a review.
    my only suggestion for you, when using Gigabyte 965 boards, is to use Memset, and manually set cas 3 or whatever your trying.
    unfortunatly, Gigabyte boards are severly good at overclocking, and just as good at giving misleading results when reviewing/testing ram.
    I have found very few ways to eliminate some of these problems.
    like running 4:5 usually will report true cas, while 1:1 will often report crazy cas.... like my 5400 UL has booted a few times at cas 4-2-2-9 on my DS9... at almost 1.1 ghz...
    Apr 2005
    Calgary, AB
    Can you be more specific on how giga boards show misleading results for RAM Kunaak. If you read ^^ I stated that I dont think cas3 is working properly for 3-4-3, what are the other problems?
    MB Reviewer for HWC
    Team OCX Bench Team
    Jun 2006
    good old Germany
    this aren't no REDLINES the REDLINE are Red
    y your RAMs have Black HS?
    Mushkin U.S.A.
    Mar 2005
    Quote Originally Posted by Kabauterman
    we ran out of redlines heatsinks. so we are shipping them with black till the reds come in.
    Mushkin Employee and DAMN Proud Of IT!
    www.mushkin.com<---new and improved
    email me <--- For any assistance or help
    Keep your eyes open... more to come.....muhahahaa
    Oct 2005
    Be happy they didnt send you Purple, they have done it before
    Nov 2005
    Chile
    Really nice sticks
    Mar 2005
    North brookfield , MA
    my set is right on par with the results posted above. ive had them for a little while. pretty good memory if you ask me.
    i have a p5b deluxe with core2duo 6400
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    WOW!!
    4-4-3 @ 2.4v/550mHz is just amazing... AMAZING!!
    Xtreme Legend
    Dec 2003
    Northern California
    Actually 550 @ 4-4-3 and that voltage is not that hard with the better RAM out there.
    When I saw 550 @ 3-4-3, my eyes nearly popped out. Even if it's a bug, still looks like decent memory.
    Thanks for doing the tests, Eldonko.
    Apr 2005
    Calgary, AB
    The vdimm measures low too, so 2.37 is more like 2.31-2.33 DMM. Although 3-4-3 doesnt do much over 4-4-3 (see comparo below). It's just the platform though, there would be much more of a performance increase because of tight timings for AM2. C2D is all about speed, gunna take some getting used to heh heh.
    CAS 4
    CAS 3
    MB Reviewer for HWC
    Team OCX Bench Team
    May 2005
    earth......among the the others
    nice ram u got there....
  18. #18
    Xtreme Cruncher
    Jun 2006
    Murrieta, CA
    Great test thank you. I have 4 gigs of this and can not wait to test it out.
    Once known as GibbonThree
  19. #19
    Apr 2005
    Calgary, AB
    Thanks GibbonThree, hope ya get some good sticks. I am just about finished reviewing xp2-8500 as well (the latest release from Mushkin) and will post shortly.
    MB Reviewer for HWC
    Team OCX Bench Team
