+ Reply to Thread
Results 1 to 2 of 2
Thread: stability problems
    Mar 2006
    0
    Unhappy stability problems
    my specs are
    athlon64 3200+ DH-E6
    DFI NF3 U-D Bios 7.11
    2x512mb 3200 ocz el platinum rev2.0 v1.0
    3 IDE hdds
    antec true 480
    x800xt PE
    Problem is my comp became unstable after i hooked up my new ocz el ram . In memtest ram is stable 2.5.4.3.7 290mhs 5 hours loop .When i boot to windows im unstable even at 200mhs lol . Cant pass OCCt and prime fails in few minutes . Didn't have problems with my previous value ram which was running at 230mhs and cpu can do 2.6ghs at 1.6v . Tried almost all memory timing combination from loosest to tightest no luck , +v on ram no luck , orange or yellow slots no luck , tryed 2 bioses also no difference. It looks like my MB doesn't like tccd or what can i try else ??
    Sep 2005
    0
    There were a ton of bios released for that board. The one your using doesn't seem to play nice with those modules. Try a different one. PM OldGuy over at dfi street. If anyone can help you with that board he can as he was one of the early adopters of that board and managed to out clock everyone else with it. Unfortunately he recently sold the board and I wasn't able to get it from him but he will probably remember what bios worked the best with those modules. I saw your post over there but was unable to reply cuz I'm banned from posting for NO FRIGGEN REASON AT ALL. Good luck.
    Gigabutt X58 OC F3 Bios
    Xeon 5680 200x21@1.34V.Vtt 1.295V.
    3x4 gigs Samsung 2Ghz 10,11,10,31@1.5V.
    3xSapphire 5870
    PCPC 950watt
+ Reply to Thread
