+ Reply to Thread
Results 1 to 4 of 4
Thread: PCI raid controller
    I am Xtreme Zeus's Avatar
    Feb 2003
    Netherlands
    7
    Question PCI raid controller
    Right now i have just one Maxtor ATA133 40Gig.7200rpm harddisk but i would like to double my harddiskspace by getting another identical harddisk.
    I want these disks to operate in a raid 0 array but haven't got a raidcontroller on my mobo so i want to get myself one of these PCI raid controllers.
    Can anyone tell me what to look for and do i have to go for a brand like Highpoint or Promise or will a generic do as well?
    Is is difficult to install and is there anything i should know before making an array?
    Any help will be appreciated, thanks in advance
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    CCW
    Guest
    get a card with a highpoint chipset...they are good...prmise make good cards, so do adaptec, down to preference
    when set upo array you will need both hdd's blank, if one drive fails you lose all data, dont worry ive had 4 maxotrs in the last 10 months, to 40s and two 60s and had em raid 0 and theyve never failed
    you lose al ldata cos its stripped across drives, i.e half and half, should double read performance
    Feb 2003
    Netherlands
    7
    I'm not too concerned about losing data or HDD crashes, i just want some more speed!
    Do you mean if set up an raid 0 array i first have to format both my drives?
    Can't i just format from my bootable Win 2k CD like in a normal setup and then format? I already have one disk, the one i'm using right now and plan to buy a second one, do i first have to format this old disk w/ a bootup floppy or something?
    Performance wise do you notice any difference between Raid and regular config?
    CCW
    Guest
    Well, itll get formated during the Win2k installation so thatll be ok, they most both be exactly the same drives for best perofmrance, pergformance wise my hdd bandwidth has doubled but so has the chance of the lsos of data its fast though, i had two 40s a little while agao, now got two 60s, the two 60s are slightlty slower because they are bigger disks, RAID is a very nice technology though, you should be getting the same spepd of your disks RAID0 as most entry level U160 SCSI Drives, just not as reliable
+ Reply to Thread
