I just saw the above after I did my last post. From the website it says:Awhile back I had done the append method manually and I think I messed up one of my dat files so I stopped doing it. Looks like the append method is suppose to be better though.How do I use the sample file? Decompress it if necessary and either use it to replace your results.dat, or edit your results.dat in WordPad and append the new results (being careful not to merge lines). The latter option will mean Muon1 can use your old results as well as the downloaded ones, so is a better choice.
Yes... but... although Stephens site says the best way is the append way he would still acknowledge that its also useful to get results from the best samples aswell.
Remmeber that his site was written up back in the day when they were running diff simulations. Not everything may be a 100% applicable now.
ANd.... it takes a small amount of time at the start of each simulation to parse and load up teh results file .dat file. How big is yours? Actually I'm not entirely sure it loads the results file at each simulation OR at the start of the muon.exe run...
Either way... fell free to change the script to just append the new files.
Keeping it real!
DeXter::2xXeon2.4@3200, GF6800, PC-DL, 1gb Centon, IWT+panaflo air, Win7
Quad::Q6600(g0)@3400(1.30V), GTX275, 965P-DS3, 4gb HyperX, Asus SilentSquare (air), Win7_64U
NuQuad::Q9400@3300(1.24V), 8800GT, G31M-ES2L, 2gb Patriot, stock air (bigger Q6600 one), WinXP64
Crunch::E4300@2400, onboard, GF7100PVT-M3, 2gb Patriot CL5, stock air, Vista64U
KaptainBlaZzed hits 100,000,000 on DPAD
When you're running DPAD on a machine that doesn't have internet access, when you copy the results, do you need to copy both results.txt and results.dat to send your results in?
Nevermind, I think the answer is no results.dat. Got confused for second.
Stupid tower won't connect to the net.
Survivor
You know what annoys me about this? Is when you have a good simulation and the result is quarantined and re run 5 or more times. So the average of the middle 3 runs are the results that is submitted. BUT. You only get the points for that ONE run. Whats compounds it is that most of the time the best runs are 5xxx Mpts, as opposed to the majorith that are around 1xxx Mpts. So you run 25XXX worth of simulation, only to be awarded 5XXX Mpts.
I started a thread on teh forum to ask about this. Its far from equitable.
Norways challenge has collapsed. Well done team.
Only 4 of the cores that I put on Tuesday have sent in results and one of those was because I did a manual send. Looks like today is the big day for the most of the other cores to have enough built up to send in. I think they each do around 20,000 points per day so they have a lot stored up.
Our team already has 841,258 for today. Looks like it is going to be a super good day .
I am down to 2 cores on this until we gain some ground on the 2 projects that were added to the vault.
I have noticed that on DPAD for the same clock speed that the AMD Athlon X2 (Brisbane) is more than 10% faster then a Q6600. Most projects I see the Intel a lot faster. Last week I upgraded a Brisbane running at 2.6G to a 5050e Brisbane at 3.1G. That is the one I left on DPAD.
