"We grabbed a pair of 2.4GHz Clovertown samples and tossed them in the system, and to our pleasure, they worked just fine. Our samples used a 1066MHz FSB, although we're expecting the final chip to use a 1333MHz FSB, but the most important part of the test is that all 8 cores were detected and functional.
We ran a handful of stability tests on the Mac Pro equipped with two Clovertowns and didn't encounter any crashes with the processors, so it would seem that Clovertown will work in the Mac Pro's motherboard. We can't say with 100% certainty that you will be able to upgrade to Clovertown when it comes out, but so far the results are looking good. "
Source: http://www.anandtech.com/mac/showdoc.aspx?i=2832&p=6
