+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 51 to 63 of 63
Thread: Guide: The Art of Soldering
  1. #51
    Xtreme Cruncher CyberDruid's Avatar
    Jun 2006
    On top of a mountain
    9
    I think if you fluxed them both and used silver solder and a torch you may be able to get that to happen
    Like the guide Great layout
    20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
  2. #52
    Xtreme Addict Serpentarius's Avatar
    Jun 2007
    4
    do it have to use hard soldering? coz i'm a noob in those
    i just able to soft solderings .. i've spoken to quite a lot ppl .. they mention around 30% efficiency of thermal transfer compared to the milling which is 100%
    does it worth it? but it's much more easier that way (headaches)
  3. #53
    Jan 2009
    0
    NICE Work excellent
  4. #54
    XIP - can sit on his hair Marci's Avatar
    Jun 2002
    Wakefield, West Yorkshire, UK
    1
    can you solder 2 copper plates together? and have non-corrosion + adequate thermal transfer? Milling is not an option for me
    Issue there is warping with the heat involved on two such comparatively large surfaces... It could be done, but controlling the deformation would be tricky. You're moving from electrical soldering into mechanical (?) soldering there... then you've got maintaining the pressure of the two plates against each other while you solder... where the clamps would be, or vertical load weight, would affect the heat dispersion and thus the thermal quality of the bond...
    S'doable, but guaranteeing performance of the end product becomes difficult.
  5. #55
    XS_THE_MACHINE [XC] moddolicous's Avatar
    Nov 2004
    Long Island
    1
    So it isn't computer related, but it is soldering related. I'm trying to solder a ring terminal to 4gauge wiring, but it is a real PITA. Am I correct in guessing that I should crimp to the best of my abilities (don't have an actual crimper) then use a torch to heat the area up and feed the solder in, or is there a better way? I have some soldering experience, but nothing on wire this thick. The electrician in me wants to do it by myself, and the cautious person in me wants to stop by the electrical shop near my house and have them do perform this.
    "Victory is always possible for the person who refuses to stop fighting"
    clicks to save kids
  6. #56
    Nov 2009
    0
    Great guide!!! I absolutely needed this, I am about to embark on a pretty wild little project
    CPU------------i7-930 @ 4.8ghz (on watta)
    Motherboard------EVGA Classified E760 (bios: 44)
    Memory---------- 3x2gb G.Skill Trident 2005mhz 9-9-9-24-72-1T
    Graphics Card-----XFX 5870 1081mhz/1274mhz
    Hard Drive--------OCZ Vertex 60gb SSD, Seagate cuda 500gb
    Sound------- Auzen Forte/Audio Technica AD700's
    Power Supply-----Corsair 850TX
    Case-------------Antec 1200
    CPU cooling-----HK 3.0 - BI GTX480 - 8x San Ace 120 w/Shrouds - MCP 355 with XSPC Top
    OS---------------Win7 64bit Ultimate
    Monitor-----------24" Acer and 20" Acer
  7. #57
    Jul 2009
    Belgium
    0
    thanks for the great guide!!
  8. #58
    Xtreme Guru Johnny87au's Avatar
    Jun 2010
    In the Land down -under-
    0
    Thanks mate gonna keep this for later reference, might try a few mods on some old cards!
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  9. #59
    Xtreme Member pogiman's Avatar
    Jul 2006
    0
    wow good guide. I solder a lot myself and this is a good refresh for me.
    Mobo|Gigabyte P55A-UD3P
    CPU|i5 760 @ 4.2GHz 1.22V
    RAM|G.Skill 8GB (2GBx4) 9-8-7-20
    Graphics|HD 4890 1GB @ 970/1100
    Cooling|MCP655>Apogee>Maze4>MCW30>360 GTX Extreme (3x delta 130CFM!)|Hi-Flo Res
    Power|OCZ Modxstream 700W
    Storage|320GB RAID 0 Intel SSD X25-M G2, 4x2TB WD20EARS
    Audio|SB Audigy 2 Platinum ZS w/ NE5532+Rubycon caps, EMU 0404 USB w/ ELNA Cerafine caps+BB 2132U opamps
    Cans|Denon D2000 Markl Mod and cable mods
    Home|CM Stacker 830
    Display|2x Samsung 2333W
  10. #60
    Xtreme Guru trans am's Avatar
    Jul 2004
    7
    dudes I am about to get this. http://www.amazon.com/Jumbo-Helping-.../dp/B001U8XVOS
    my eyes get strained so badly. Anyone else like to share similar rigs to keep your hands free and bright and magnified?
  11. #61
    I am Xtreme tiro_uspsss's Avatar
    Jan 2006
    bouncing between Perth & Sydney
    40
    Quote Originally Posted by trans am View Post
    oo nice!
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    the yummy FOOD
    thread
    heatware / ebay
  12. #62
    Xtreme Member musicfan's Avatar
    Jun 2010
    Oregon, USA
    25
    Great guide. Thank you.
    Cooler Master HAF 932 case; Corsair 850 tx psu; Dell 24" monitor
    XSPC rx rads; Apogee xt; gtx285+Danger Den block; mcp655's in EK-D5
    distilled water + silver in MasterKleer 7/16" ID on 1/2" barbs & compressions
  13. #63
    Oct 2012
    0
    great info the more i watch the crazier i feel myself getting with my hardware lol
    3770K @ 4.9ghz | Asus Maximums Formula | 2xSLI GTX 660 ti 3gb 1330/7000 | Gskill 4x4 @ 2133 | custom water loop all EK blocks
+ Reply to Thread
