Yes, that is the one advantage of Kentsfield. It can be run in almost any Conroe board. The CPU booted in every board I tried. I've sold my Kentsfield. It will soon be in the hands of a very capable overclocker.Originally Posted by wtfdc
I would be interested in seeing how fast it can encode using SVCD2DVD.
You can get the demo version here:
http://www.svcd2dvd.com/
Nice stuff...
________
Ford Model B (1932)
sierra_bound
what cooling? 4ghz, 4cores = incredible
i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
I believe I was using phase change cooling. That was done awhile ago. I would have gotten higher clocks, but I ran into a FSB wall on the board I was using. Also, the board did have multiplier options past x10. On Asus 975X boards, multipliers up to x20 would have been available for Kentsfield. Running FSB at close to 400 did help, however, at least in Cinebench.
One extra difference, on kentsfield all four cores share the fsb, cloverton has dual independent busses so each socket has two fsb paths. If you run SPi 1m four times on kentsfield you'll get around 25 seconds each (I think thats close to the stock times), if you run it 8 times on this guys dual socket it'll be closer to 20 seconds each.Originally Posted by AndrewZorn
In theory anyway.
I don't know if 25 seconds is accurate. Of course I never ran my Kentsfield at stock speed.
Also keep in mind that two Clovertowns and a good server board are going to probably cost you at least $2500. That's out of the financial reach of many people.
$2500 is probably a very conservative figure, especially if you wish to be an early adopter. Kentsfield ES chips are going for $1500-1700. I'm sure Clovertown ES chips will command similar prices. So maybe $3000-3500 is more likely for dual Clovertowns and a nice board.
lol I know, but it was one of the few pieces of information missing from this thread.
Edit: Once intel rip off AMD's hyper transport, and have a native quad core on market, they'll probably just pull the same trick again to do 8 cores on one socket. Intel definatly 'have form' in that area.
U r not supposed to sell any ES chips from Intel, It has Intel confidential stamped on it . Property of Intel , technically it's on loan from Intel to you .Originally Posted by sierra_bound
Yes, I know. Several people have recently sold Kentsfield chips here. Anyway, the chip is no longer in my possession. And I'm not going to reveal the identity of the buyer.
ES chips have been circulating for years. Intel knows they are out there. They don't like it when they are sold on the open market. But it would take them a million years to track down every engineering sample.
How do u test this ? There is no benchmarks to runOriginally Posted by BandofBrothers
try the benches in bionc!!!!!!!! and then show us at the wcg section what that monster is made of!!!!!!
CPU: Intel Core i7 3930K @ 4.5GHz
Mobo: Asus Rampage IV Extreme
RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
GPU: EVGA GTX Titan (1087Boost/6700Mem)
Physx: Evga GTX 560 2GB
Sound: Creative XFI Titanium
Case: Modded 700D
PSU: Corsair 1200AX (Fully Sleeved)
Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
wow, 8 cores
Asrock Z68 Extreme4 Gen3
•i5 2500k @ 4.5ghz - 1.32v - CM Hyper 212 Evo
•G.Skill F3-12800CL9D-8GB
•ASUS 7850 @ 1250//5800
•Corsair TX650 V2
•Dell 3007WFP
•Win 7 64 Ult
How about a few screenshots of load/idle with Core Temp running?
http://www.xtremesystems.org/forums/...d.php?t=103638
Member of Overclockers.com Folding @ Home team
"<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
Main rig:
AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
Secondary rigs:
Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
Wow, so many cores...
When is it coming out? What will be the new socket using it?
Core i7 4790K // CM Hyper 212+ // Asus Z97-Pro (BIOS v.1304) // GTX 780 DCII
Corsair XMS3 2x8GB // Intel 335 SSD (240GB) // Corsair HX650W // Lian Li PC-A10
is uses socket 771 for Xeon DP and Xeon MPOriginally Posted by Mr.X
Desktop
Intel Wolfdale E5200 @2.9Ghz
MSI P6N SLI Fi
Gigabyte Radeon HD4850ZL @ 680/2000
2GB Crucial BallistiX D9GMH 800 4-4-4-12 1T
250GB & 400GB Western Digital SATA2
Sound Blaster Audigy2 ZS
Enermax Liberty 500W
Air Cooling (Arctic Freezer 7 Pro)
Originally Posted by luihed
No one programm to test? Try it: http://benchqueens.narod.ru
IT can work with 1-16 cpu...
that's a bit of a shame that it isn't using all the cores 100%Originally Posted by wtfdc
SuperPi Multi CPU - is not very good... Java is multiplatform language and it so SLOW...
"Queens" use 1-16 CPU programmed on cleaer assembler and compiled using
"Hand Made" Intel Netburst optimisation...
So,
And if you have 4 CPUs mashine, i can suggest
http://nuc-rus.narod.ru
Can you run BootMark, please ...
Download here:
http://download.boot.lv/files/^Testu...ww.boot.lv.rar
Impressive - just how can us mere mortals afford this?
Would go nice with some decent quad SLI support from nVidia, and 2x 7950's, and yes, DX10. If only 7950's were DX10 cards
Should give us 20k scores in 3dM06 at close to stock.
Good, cannot wait for this, and DX10 cards.
Never argue with Idiots...they will drag you down to their level and beat you with experience!
i-Prodigy (small APD2 GFX/CPU waterloop) ; HP Blackbird Project Log (dual-Xeon Watercooled) ; Macho Mini Project Log (Sandybridge watercooled mini-ITX)
Can I ask what applications you run on that server for your needs?
Originally Posted by TaPaKaH
It is not even near multithreaded
