Results 1 to 2 of 2
Thread: Bench Results
    Aug 2004
    Inverness, Florida
    Bench Results
    Using Xbench what does your Mac score? I am using only a MacBook with a 2.0 Core Duo and 1GB RAM with a 80GB HDD. Just curious to compare. Please post in a easy to read format.
    Code:
    Results	91.86
    	System Info
    		Xbench Version		1.3
    		System Version		10.4.7 (8J2135a)
    		Physical RAM		1024 MB
    		Model		MacBook1,1
    		Drive Type		ST98823AS
    	CPU Test	72.56
    		GCD Loop	251.08	13.24 Mops/sec
    		Floating Point Basic	90.72	2.16 Gflop/sec
    		vecLib FFT	39.38	1.30 Gflop/sec
    		Floating Point Library	67.91	11.83 Mops/sec
    	Thread Test	194.58
    		Computation	176.34	3.57 Mops/sec, 4 threads
    		Lock Contention	217.04	9.34 Mlocks/sec, 4 threads
    	Memory Test	117.30
    		System	113.40
    			Allocate	120.81	443.64 Kalloc/sec
    			Fill	107.92	5247.31 MB/sec
    			Copy	112.22	2317.94 MB/sec
    		Stream	121.48
    			Copy	115.76	2390.90 MB/sec
    			Scale	116.09	2398.46 MB/sec
    			Add	128.26	2732.11 MB/sec
    			Triad	126.93	2715.38 MB/sec
    	Quartz Graphics Test	92.05
    		Line	92.35	6.15 Klines/sec [50% alpha]
    		Rectangle	98.41	29.38 Krects/sec [50% alpha]
    		Circle	98.30	8.01 Kcircles/sec [50% alpha]
    		Bezier	108.84	2.75 Kbeziers/sec [50% alpha]
    		Text	71.59	4.48 Kchars/sec
    	OpenGL Graphics Test	220.11
    		Spinning Squares	220.11	279.22 frames/sec
    	User Interface Test	194.61
    		Elements	194.61	893.16 refresh/sec
    	Disk Test	35.45
    		Sequential	61.78
    			Uncached Write	69.20	42.49 MB/sec [4K blocks]
    			Uncached Write	64.17	36.31 MB/sec [256K blocks]
    			Uncached Read	49.11	14.37 MB/sec [4K blocks]
    			Uncached Read	69.70	35.03 MB/sec [256K blocks]
    		Random	24.86
    			Uncached Write	8.34	0.88 MB/sec [4K blocks]
    			Uncached Write	62.35	19.96 MB/sec [256K blocks]
    			Uncached Read	70.19	0.50 MB/sec [4K blocks]
    			Uncached Read	93.70	17.39 MB/sec [256K blocks]
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    1TB HDD + 2TB Ext + 1TB Ext
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    2GB+1GB G.Skill DDR2
    320GB HDD
    ATI HD 2600 Pro 256MB
    16GB iPhone 3GS
    GamerTag: ugp
    GamerTag: SadisticPuppets
    May 2005
    Denmark
    My MacBook Pro has been in for repair, getting it back monday so will be sure to post some results
    Never Argue With An Idiot. They'll Lower You To Their Level And Then Beat You With Experience!
