I discovered that i had the same block running on 2 different machines last night. And also have had problems with SBQueue giving out a new block and then finding out that the client that requested the block THEN simply startyed on a block that another client was already working on. Had used sobsvc -o2 to set up the service install on the DX. Getting a little confused by all this. SBQueue dished out the block (because one less in its fetched list), but there were only 2 zXXXXXX files in the SB folder. Went into the registry and found that cache & cache2 were set to the same n numbers. getting mad now.
SBQueue is on one machine and all the others point to it over a wireless network. Anyone else have this experience?
How do I get my DX back to actually crunchin 3 clients if I only have 2 zXXXXXX files in SB folder and therefore don't know what to set the n/k values in the cache values in the registry! Reinstall?
