Here's my idea... I'm mounting my pump (Iwaki MD-20RLZ) in 5.25 bays 2 and 3, and my reservoir in the 5.25 bay 1. The pump will pull water from the res right above it, pump it directly out the top of the case, down the middle of the top, to the radiator in the back (BIX III) then all the way back down the middle of the case, back in the top, down the backside to the quad-sli blocks, back up the side and into the radiator.
I'm using 1/2" ID tygon and the blocks are G1/8 threaded (there's a set of fittings for a single card's block for a total of 2 sets, not 4).
Basically, I'm wondering with the tubing, radiator, blocks, and layout specified, would this pump be able to handle it? It's a mid-tower ATX case. I was thinking because it's got a pretty good journey and a big radiator, AND high pressure blocks, it might not be able to keep up.
Any advice would be appreciated.
Do you think this will work, or should I ditch the whole tubes out the top method, move the pump to the bottom of the case, and have the tubes go directly in and out of the case for the radiator?
Yea so I suck at drawing.
One other question on the side, about this pump. I'm planning on making an AC relay for it and mounting in the top expansion slot... does anyone know if it has bare leads or would I have to cut the power cord?
