Lol so you say the thing to read your temps correctly is asusprobe- speedfan ect? What about coretemp / everest? Im sorry Im confused now.Originally Posted by Fred_Pohl
E6600/Asus P5W DH/X1900XT/ Enermax Liberty 620w PSU/ Raptor 74gig/G.Skill 2GB DDR2 NR PC2-6400
Maxtor 250gig / Antec P180 / Audigy 2 ZS
[$0.02]The temp reading in RMClock is new. It was recently added and has not been debugged. I say this because the values it displays are flatly WRONG! I'd bet the next version will have this addressed. Until then, use whatever tool you like except RMClock.[/$0.02]Originally Posted by Jimbo
Intel D975XBX (Intel i975-ICH7R) (BIOS 1351)
Intel Conroe E6600 @3.4GHz Stepping 6 Rev B2
(Vcore=1.425V, Vmch=1.525V, Vfsb=1.271V)
GIGABYTE G-Power Pro Cooler GH-PDU21-MF (Heatsink/Fan)
Corsair TWIN2X2048-6400C4 2GB (2*1GB) DDR2 PC-6400 (@2.1V)
2*BFGTech GeForce 7900GT OC PCI-E 256MB GDDR3 SLI
Seasonic USA S12 Energy Plus 650W Quad Rail PSU
Samsung SyncMaster 213T LCD 21" Monitor (1600x1200@60Hz)
Matsh1ta DVD-RAM RW SW-9585
Western Digital WD1200JD SATA 111GB (Drive C)
Maxtor 6L250R0 SATA 233GB (Drive D)
Intel 82573E/82573L Gigabit Ethernet (Driver 11.0.45.0)
SigmaTel STAC9221 8-Channel High Definition Audio (Driver 5.10.5143.0)
Thanks for your advice, I went to ininstall RightMark and the sob doest even have a uninstaller.
Here's something to think about, how do you actually know which program is reporting the correct temp. and what is the correct temperature?
Ive used a number of different applications to check out the temp and they all report different readings
Everest
CoreTemp
PC Wizard 2006
RMClock
So how would you even know which is correct or even if any of them are.
I don't trust any of them now. My C2D hits 78C @ 3.2ghz and is Orthos stable for 12 hours, so I don't really care if the temps are misreported. I've tried my best to make good contact with a nice heatsink (Ultra-120, and it gets warm, so there is good contact), so there really isn't much more I can do except believe Coretemp and Co. are misreporting on certain configurations.
I remember reading the opposite but can't find where. It was said that céramique was better with flat and scratchless surfaces due to the fact that it's particles are smaller than the ones of AS5 (0.38 microns vs 0.49 microns) and thus being more efficient at filling microscopic valleys.Originally Posted by LagunaX
AS5 is non-conductive too but it is very slightly capacitive though.Originally Posted by mesyn191
I did my own test with AS céramique vs AS5, I mounted my HSF with céramique and waited a week.
Idle 39C
DP load 61C
I then remounted it & waited another week, same temps.
I then tried AS5 yesterday and this morning my idle temp was already lower @ 37/38C (no load temps yet)...it may get better in the next few days.
I used a drop in the center of the CPU slightly smaller than a BB for both the AS céramique and AS5 test.
Temps based on:
24/7 DP stable 1.5 vcore 333FSB@3.3Ghz
fanspeed for Idle & load temps at (quiet) ~2000rpm....will go to 4000rpm for better cooling but it's loud.
I made sure ambient was the same in all tests.
Core 2 Quad Q6600 G0 L723A930
3.6GHz 24/7
ASUS P5K Deluxe Mobo
Thermalright Ultima-90
Sapphire HD 2900 XT
2x1G Mushkin XP2 DDR2 800MHz
OCZ GameXStream 700W PSU
Antec 900 Case
2X WD Raptor
Vista
Yes but what program are you using to get those temps above? or are you just reading it straight from the bios?
Temp reading from AiBooster, Everest, & ProbeII in all tests...all read the same.Originally Posted by Jimbo
I'm not trying to show how good or bad my cooler temps are here (Yes, I know CoreTemp shows ~14C higher), I'm trying to show my experience between the different temps when using AS5 or céramique.
3.6GHz 24/7
Sapphire HD 2900 XT
Antec 900 Case
2X WD Raptor
Vista
