Which WUs did you select in your profile when you signed up for WCG? i selected all 3 types... Did everyone else?
Yeah, but mainly Cancer and Proteome (sp?). I chose those two. But since the Proteome one isn't, at this time, sending out WU's, and not all my machines have enough RAM for the Cancer WUs, then I also get some FAAH's ( I have "send me anything, keep me busy' checked ).
Crunching to Crush Cancer
Somebody, Stop Me!
i selected cancer, and then checked the box to keep me busy if there is no work for cancer
STARSCREAM
3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
MEGATRON
3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
Corsair AX650 | Corsair H80i
same with you guys. how much ram does cancer need? cuz i have a couple rigs with less than 512mb
CPU: Intel Core i7 3930K @ 4.5GHz
Mobo: Asus Rampage IV Extreme
RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
GPU: EVGA GTX Titan (1087Boost/6700Mem)
Physx: Evga GTX 560 2GB
Sound: Creative XFI Titanium
Case: Modded 700D
PSU: Corsair 1200AX (Fully Sleeved)
Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
Heres a cut and paste from wcg's requirements page for the various projects. Cancer takes quite alot I think you may want to check out the other projects for the lower memory machines, cancer really lays it to your mrm i'm not kidding. (this is for windows)Originally Posted by hipno650
What are the recommended minimum system specifications for a Windows system?
Each research project we run on the World Community Grid has different minimum machines requirements.
For the Help Defeat Cancer project, the minimum requirements are:
At least a 200MHz Intel Pentiumâ„¢ processor or equivalent
At least 750 MB RAM (virtual memory should also be enabled)
2000 MB Hard Disk Drive with at least 500 MB available for use
The ability to display 8-bit graphics at 800x600 resolution
An Internet connection with minimum 40 kbps speed
Operating System: Windows 98, ME, 2000 or XP
For FightAIDS@Home, the minimum requirements are:
At least a 550MHz Intel Pentiumâ„¢ processor or equivalent
At least 250 MB RAM (virtual memory should also be enabled)
600 MB Hard Disk Drive with at least 50 MB available for use
For the Human Proteome Folding - Phase 2 project, the minimum requirements are:
600 MB Hard Disk Drive with at least 100 MB available for use
Does anyone know what the different types of projects are called as WU? FAAH is the Aids project and the other two?
hdc is cancer. havent seen proteome yet.
