I got my AGOIA 2100+ processor and ive got it at 11x180Mhz. This is on KX7-333R and KX7 Heatsink. Any help on maybe getting it to go faster? Maybe get my multiplyer to 10??
-AMD XP 2000+ (AGOIA Core) @ 1980Mhz
-Abit KX7-333R
-PNY Verto GeForce4 4400Ti
-512MB Samsung DDR2700
-60GB Seagate Barracuda IV, 40GB Western Digital.
-Creative Sound Blaster Live!
-52x Asus, 24x10x40 Lite-On CD-RW
-400 Watt Enermax
-Thermalright AX-7 with Thermalright 80mm fan.
-Optiquest Q75 17" Monitor
->I have Penguins glued to my case, and monitor!! What about you?
*Beware of the Penguin! Be afraid; be very afraid!
**Long live the big Brown Fuzzy Mammal!
1980mhz aircooled?!?!
Is it completely stable with sandra burn in?
You could try lowering the multiplier and raising the FSB. Higher FSB equates to higher memory speed and overall better performance. Your Samsung RAM should go pretty high with enough volts.
wow thats a nice oc aircooled. Yeah, how stable is it? Can you run prime for awhile.
Your sig says
and your post :
lol, I wanna know. Either way thats a hell of a oc without a vapo etc.
I ran Prime95 all last night and it was still chuggin away 9 hours later!
-Abit KX7-333R
-400 Watt Enermax
is it a 2100+ or a 2200
can I see what memscores you have at 180 with 2 gig of processor power? just curious how much higher they were than my old xp that was 10*180.
fx-53@210*14@1.7V, asus x800xt-PE peltier cooled-Vapochill ls
The maddest in hardware!!
Its a 2100+ and the rest of the question is non-understandable. At least i dont understand. Let me know.
-Abit KX7-333R
-400 Watt Enermax
what are you saying?? what question....
TurboP, Calantak wanted to see what your sandra mem scores look like with that cpu speed.
JBELL,
I believe this thread is a direct result of hitting the "new thread" button as opposed to the "post reply" one.
Can't say I haven't done it myself in the past...but since i don't usually put a subject in my replies...it warns me that I've messed up
E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
LMAO
where does this go ... I will merge the threads
http://www.xtremesystems.org/forums/...&threadid=1089
this is the thread where this belongs
