ok guys I did it and bought the SOYO KT333 DRAGON ULTRA
and installing it into my water case which I already posted in here...
what do I need to do to fill and bleed the lines?
A large temporary resevoir or a fill and bleed valving system like Swiftech sells.
how fast can you send me a fill and bleed?Originally posted by DaGoochMeister
and say 4-5 feet minimum of swiftech grade tubing
You really dont need a resevoir, I never used one as they are pretty much useless unless your pump isn't capable of running Inline.
Just make a fill line like this:
P4 3.2
P4C800-E
Xtreme Tek Werkz Typhoon waterblock
Maze4 GPU Waterblock
Mcx159-P w/10,500rpm counter-rotating 50mm JMC fan
Mushin BH-5 Promo build 2-2-2
9800 pro with silversink ramsinks
WD Raptors
My Heatware
i am up and running after cpu fan sensor scare and bad video card...
whats yoru temps???
I am getting 33c/43c with maze2 block
Originally posted by JBELL
whats yoru temps???
P4 1.8a @2.4 temps at full load 36*c (new air filter dropped temps 2*) Used to run 38*full load
Maze2 P4 Eheim 1250/ Inline Standard heater core
(Oh yah these temps are with fans at 50% and barely audible, temps drop lower but I like a silent pc/ Water temps are 27.7* ambient is 24
P4 3.2
P4C800-E
WD Raptors
My Heatware
Nice radiator setup there SilverSink. JBell, a resevoir usually just promotes much quicker evaporation from your system compared to a closed loop system with a good inline pump.
Damn right thats a nice radiator.....thing is its not mine, thats Hoots from Oc.com. It was just a good pic I had to explain the lack of not needing a resevoir.Originally posted by DaGoochMeister
My setup is similiar, except i have a Eheim 1250 and use a loop to cool my Northbridge....But I gotta admit Hoots Shroud is pretty sweet.
P4 3.2
P4C800-E
WD Raptors
My Heatware
Yes, the shroud and the dual 120mm fan setup is pretty sweet.
Hi Silversink, I have a question because I am running 2.4 at this moment with 38C load temps at 24C ambient. Just for my own comparison sake, what voltage do you run at? I need 1.79v with my 1.6A.Originally posted by Silversink
Thanks.
Welcome to Xtreme hope you stay awhile.
Yo Gone Fishin Welcome aboard!
Thanks for the welcome, I'll be stickin around
