bit of help with high detail tests if you would....
Hi guys.
Basically ive hit an impasse with my score. Looking at my project details my low res tests are much higher than the guy above me in 2nd place, but my high res tests are substantially lower. Det drivers im using are supposed to be faster (my 29:40 versus his 29:20), my gfx card is clocked 35/13 higher than his too. He has a much higher cpu speed and rdram, but my low res tests would indicate that this advantage isnt whats stopping me getting up top. Maybe some sort of driver tweak im not aware of?
Any help appreciated,
PiLsY.
[EDIT] - Should probably include the 3dmark compare : 7551.
that's kinda funny...my prollem is the other way around
my low res scores are not very good when comparing to others on the orb that i'm smoking in high res.
E8600. EP45-UD3P. 500FSB 24/7. Still WinXP. Heatware
- You may not post replies
- You may not edit your posts
Forum Rules
