recent conversations in various threads here at XS has brought up the fact that AM2 is slow. if you have graduated from 939 to AM2 then you know what i am talking about...AM2 is slow. that isn't fair, it can be faster but requires primo gear and the gains are marginable.
that said, AM2 is only marginably slower than 939. i finally have a few AM2 motherboards, CPUs, and a pair of memory kits through the workbench and so i figured i was armed with enough knowledge of my newer AM2 gear and take a legitimate run at my personal best 1M and 32M Super Pi times at 300*10=3GHz. here is how it shook out after a few hours messing with the AM2 rig:
Obviously 939 has a slight advantage in the two setups above, depending on opinion of course, due to the larger cache. Other than 300*10, there are no rules except to get a faster time using whatever means necessary.Code:Systems: 300*10 = 3000MHz for both setups Socket: AM2 | 939 MB: Asus M2N32-SLI | DFI LP Ultra-D CPU: A64 3200+ (512KB L2) | Opteron 146 (1MB L2) RAM: Corsair 2048-8500 C5 | OCZ 1024-5000 Plat. (TCCD/5) GPU: HIS X800GTO | HIS X800GTO OS: Windows XP SP2 | Windows XP SP2 PSU: OCZ GamerXStream 700w | SilverStone ST56ZF
Socket 939:
1M - 26.984 seconds_______________32M - 23m 51.687
____
Socket AM2:
1M - 26.985 seconds_______________32M - 23m 51.625
____
These numbers are of course a work in progress but I thought that it was interesting that AM2 is nipping at 939s heels after only a month or two of being out. Of course this is only Super Pi and at a restricted processor speed but I like these types of comparisons.
Please post your own Super Pi 1M and 32M runs at 300*10, especially if you are running AM2. I really want to see how others crack into the 26s with AM2. I will be trying to get the OCZ PC7200 plats I have to run 3-3-3 at DDR856 (holy voltage required batman) and see what it spits out for times in a few days.
