You can't remove the IHS of any 775 cpu. It will simply not fit in the socket anymore.
Rig : Core 2 Duo E6600 | Scythe Mine | 2x 1gb OCZ PC2-6400 Platinum XTC | Asus P5B Premium Vista Edition| eVGA 8800GTS 320Mb | 1x Seagate 80gb SATA2 2x 250gb WD SATA2 SE16 Raid0 | SB X-Fi | OCZ GameXstream 600W | Silverstone TJ06 case
Core 2 Quad Q6600 G0 L723A930
3.6GHz 24/7
ASUS P5K Deluxe Mobo
Thermalright Ultima-90
Sapphire HD 2900 XT
2x1G Mushkin XP2 DDR2 800MHz
OCZ GameXStream 700W PSU
Antec 900 Case
2X WD Raptor
Vista
Thank you, just what I needed to know.
u just linked to this same thread...Originally Posted by Icer
Rig:
Pentium D 805 3.8 GHz and counting, w/Big Typhoon (hopefully E6600 at christmas)
eVga 7900GT KO Reload, 508/1525 stock volts
MOBO SWITCH! P5B deluxe
2 GB Patriot ddr2-667 4-4-4-12
Antec NeoHE 550
250GB Seagate 7200.10
Thermaltake Soprano w/2xAspire 120mm and 1xThermaltake 90mm
Dell 19'' LCD monitor
Heat
Since transistor quality varies even on the same wafer I would choose the retail over OEM procs simply because the quality is better with a retail chip. I don't think they're cherry picked but the chips are tested and rated according to possible speed stability and branded accordingly. For a better overclock I would suggest retail.
what is that guy smoking?Originally Posted by Tallman
400$ for a .2ghz overclock on a northy?
ur kidding...
My Rig:
i7 3770k
Sabertooth Z77
MSI GTX680 reference
2x8gb Mushkin Redline 8-8-8-18 @1600
Corsair Neutron 256gb
2x Toshiba 7200rpm 3TB(Raid 0)
Corsair 600T White
Corsair HX750
Asus PCE-AC66
Hanns-G 27"
I got 3.15Ghz stable on a week 26 OEM stock Vcore (But it was $20 cheaper than Retail, and I just wanted an easy time putting my HS on, plus it had a 1 year warranty which is enough for me, but isn't overclocking voiding the warranty anyway?)
