http://www.free-dc.org/forum/showthread.php?t=11431
Seems that there is no limit on the number of clients that can be run now, so ramp em up ppl. This project uses less bandwidth than Dimes or majestic and doesnt require VMs.
You mean i can open more than one client in the same OS?
If yes, then yea i'm in!
It appears that way from what I read. Seems you need to copy the folder and then open a new .exe
I cant try at the moment as my remote access is playing up atm and most of my machines are down due to the never ending heat.
Yea i'm worried about the heat too, my air-con has been on for more than 48 hours non-stop!
I'll try copying the whole directory, and report back.
EDIT: It works! I just stopped the old client copied the whole directory to a new location and renamed the .exe file and it worked!
Screenie to prove
You just beat me to it. I have just setup about 30 instances on 2 machines. Lets see how it does.
I got 11 so far will add more if it all goes well!
Oh God. That red library sounds good to me too. Damn I need to get back somewhere where i more than dialup. Tell me, how big is the ram & Virtual Mem?
Seems one of my rigs doesnt like bandwidth DC projects anymore, no mj12 or red on that one. Shame as it had 30 clients ready to go.
What becomes the bottleneck first for red library then if we dont need vm's is it ram or cpu? either way ill go full blast for a bit
P.S. whats taking them so long with this linux client....
[EDIT] It seems the cpu is the most immediate bottleneck as I only have 512mb of ram and am running 23 clients. I will leave them run and see how they do but it means my rosetta output will drop thanks to the clients sucking every last drop of cpu power, if all the clients get points then I may set it up on some P3's as a set and forgot as my current computers becoming unreponsive with all these clients. [/EDIT]
where do I go to get setup?
I googled it but theyr sites not very helpfull :S
cheers, Ed
Conroe E6420 @ 3.3ghz at the moment.
DFI Dark P965
2gb Geil DDR800 4-4-4-12
8800GTS 512mb
1.7TB Storage
CM Stacker
http://www.readyresponse.org/index.p...tributed&opt=7Originally Posted by eddieate
Thats the red library download page with the clients if thats what your after it also has links to everything else on it.
For some reason I can never find it unless linked to it the website is horrible to negotiate
[EDIT] OK i've been watching my taskmanager for a bit and it is infact the ram that is still the bottleneck for me. It is only 15mb per client though and i've managed 36 on 512mb and the computers still useably responsive. Shame there's no linux client though. [/EDIT]
Somebody start the Red Library thread. I nominate Mely and Wild Blue to be the first contributors. Hom much VMem does rach take. 15ram and how much Virtual?
I think the task bar is the limiting factor
On this small CRT monitor it makes my desktop look even smaller
Can you not set it to just auto hide taskbar?Originally Posted by hixie
Also crt's still rock I just upgraded my 15" crt montior for a 17" crt I found on the street can't beat the price and better performance than a 17" or 19" flatty
I can ... the problem is when i then expand it .... all i see is Red Library.
Moved the task up a bit, got 30 clients now.
keep adding the clients, im upto 67 now and there all working but I have run out of computers as I'm selling most for cash and conroesOriginally Posted by hixie
Cheers I'll get on that in a minute.Originally Posted by melymel2789
Ed.
DFI Dark P965
8800GTS 512mb
1.7TB Storage
CM Stacker
I was planning on getting 60 clients up in the next hour or twoOriginally Posted by melymel2789
That's good to hear hixie let's get XS to top 3 atleast! it's a bit annoying to see that what i've slowly gathered over several months Is out produced in one day thoughOriginally Posted by hixie
What i gathered in 2 days was out produced in a single update!Originally Posted by melymel2789
Anyways, in a few months my lease to my appartment will expire, and for the first time i'm going to buy a flat and not rent one . The flat i have in mind will have a 100Mbps up and down line, but i know that their ping rates are really high. So i'm wondering will the large bandwidth be enough to overcome the high ping rates? Or would it not matter for these bandwidth projects?
dammit how long does it take to send the registration email!!
DFI Dark P965
8800GTS 512mb
1.7TB Storage
CM Stacker
Do you have hotmail? If you do it most likely went to the junk mail folder.
I didn't get mine for 3 hours and when i looked at my junk mail folder there is was!
Gmail, and its not in the spam, unless its entitled "VIAGRA, CIALiS - web lowest prices"
DFI Dark P965
8800GTS 512mb
1.7TB Storage
CM Stacker
