Results 1 to 14 of 14
Thread: Kentsfield X6700 @ 4550MHz - Tyrou
    Skulltrail Addict - XIP
    Nov 2004
    France
    New Max Frequency WR on a QuadCore Kentsfield : 4550MHz
    CPU-Z Validation : http://valid.x86-secret.com/show_oc.php?id=107258
    After the 4455MHz I've got with that cpu, I've been convinced it deserves a well vmodded m/b to run on, 1.54v was a shame Now, it's 1.72v, and I can still go higher (up to 1.78v)...
    The major issue is still the max fsb, now I simply can't go any higher than 267MHz, it's really upsetting me, whatever I try, I can't do anything to fix this, I've tried several fsb straps (533/800/1066, the 1333 won't boot at all), any Vmch, tried to set in the bios or in clockgen... and, for sure, i use the last Intel bios, which is supposed to improve the o/c a bit... that board sucks with a Kentsfield, that's all.
    4550MHz doesn't seem to be the max I can get, I was just too busy to fight with combinations of high multipliers and low fsb today, but I promise, i'll be back tomorrow
    • The three stages cascade cooler : http://www.cooling-masters.com/forum...opic=2950&st=0
      (it's in French, but pics should speak by themselves, otherwise, feel free to ask for infos)
    • System specs :
      Bad Axe rev304 modded(vcore/vddr)
      Kentsfield 6700 QMAM
      2*1GB 6400C3 + 2*1GB 8500C5
      Matrox Millenium
      Raptor 36GB
      PCP 850SSI
    Xtreme Legend
    Dec 2003
    Northern California
    Good job again, Tyrou. I noticed coolaler was also using a high multiplier and low FSB to get 4462MHz. Interesting CPU.
    Jun 2004
    near Boston, MA, USA
    Congrats. It sounds like an uphill battle but you are doing well in spite of it. Well done
    Xtreme X.I.P.
    Aug 2004
    Chile
    have you tryed better cooling on the nb?
    Apr 2006
    Really nice overclock Tyrou...you keep battling away!
    Jan 2006
    Lithuania, Kaunas
    4550MHz
    congrats m8
    very very nice indeed
    At what maximum clock you can run benches?
    Feb 2006
    Toronto, Ontario and USA
    wow, congrats. while most people are still playing with conroes, you and coolaler are already playing with Kentsfield!
    quote from batman: "where does he get those toys?"
    Intel Q6600 G0
    DFI LANPARTY DK P35-T2RS
    4gb GSkill PC8000 PQ
    XFX 7800GT 256mb
    320gb Seagate SATA
    2x 750gb WD SATA
    NEC 3550a DVD-RW
    Toshiba DVD-ROM
    Dell 2005fpw Ultrasharp
    TT Big Typhoon + Silverstone FM121 120mm
    Antec Super Lan Boy
    Nov 2005
    /Land/Spain
    Very good overclock
    I hope to see a soon super pi and some other test: D
    Feb 2006
    wow nice oc, can you please run 3dmark06 or cinebench?
    May 2006
    Well, as I'm sure everyone is aware, don't expect high FSB speeds with Kentsfield. Better than 267 should be expected, but not that much better. As you add loads to the FSB (more cores), it becomes harder to increase the frequency of the FSB because the signal degrades across the two loads (sort of). It's a good thing they're all unlocked.
    Nov 2004
    France
    that's a a good explanation, but IMO, it's more like a "bug" on the XBX, as we've seen 390MHz fsbs on the MSI board, using the same northbridge
    no problem, I'll run some benches with it
    Apr 2006
    Taiwan
    wow! u r ACE
    Nov 2003
    Great clocks. Congrats on a solid CPU.
    Dec 2005
    Northern Virginia
    i think everyone is expecting some benchmarks...
    nice overclock. too bad about the problem though. good luck with that.
    Computer:
    Case: Corsair 750D Airflow Edition
    Mobo: Gigabyte Aorus X570 Ultra
    RAM: Crucial Ballistix Sport LT 2x16gb @ stock
    CPU: AMD Ryzen 5900x
    Graphics: Evga GTX 1080 FTW, Coil Whine edition
    PSU: Corsair RMi 650w
    Cooling: Please don't remind me. Corsair H115i w/Arctic P14 PWM fans.
    HDD: 970 Pro, 860 Evo, WD 1tb 3 platter drive (12 years old?!), etc.
