Results 1 to 16 of 16
Thread: Errors...
    Live Long And Overclock perkam's Avatar
    Sep 2004
    0
    Errors...
    Is it normal to get "Unrecoverable Error"s for every task that I have ?
    Perkam
    A thing of beauty is a joy forever! Movieman's Avatar
    Nov 2005
    New Hampshire
    78
    no..what system are you running? ram,etc?
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Sep 2004
    0
    4ghz celly, ocz pc2-5400 ram at ddr2-600 4447, on Asus P5GDC Deluxe.
    I just got it to 4ghz...and had vcore issues a few days ago which should be resolved now that the vcore is at 1.58.
    Perkam
    Hiding from the cops and people I ripped off
    Jun 2005
    In Bed
    0
    Perk, are you using the screen saver? Or you might be overclocked to far and not stable for Rosetta.....
    Sep 2004
    0
    I know...its amazing. I don't have BOINC on start up. I just started up. Right after I click Submit Post my computer restarts.
    I was like "WOW, Opp must be right, Rosetta IS better than P95 at Stability Testing". My vcore was set at 1.51 in the bios and was fluctuating to 1.58 on cpuz...nuts. Just increased it. Lost 6 tasks last 5 mins that way
    EDIT: Just confirmed...Its stable now. Thx guys.
    Perkam
    Mar 2006
    United States of America
    0
    Here, look at this:
    29577861 25391825 22 Jul 2006 12:54:12 UTC 22 Jul 2006 18:22:25 UTC Over Success Done 10,590.36 132.07 132.07
    29574444 25388546 22 Jul 2006 16:15:03 UTC 29 Jul 2006 16:15:03 UTC In Progress Unknown New --- --- ---
    29542572 25358527 22 Jul 2006 6:58:01 UTC 22 Jul 2006 11:30:16 UTC Over Success Done 10,588.97 132.05 132.05
    29524446 25341268 22 Jul 2006 3:49:02 UTC 22 Jul 2006 8:31:18 UTC Over Success Done 10,682.63 133.22 133.22
    29507921 25325379 22 Jul 2006 0:55:20 UTC 22 Jul 2006 5:30:20 UTC Over Success Done 10,701.80 133.46 133.46
    29498656 25316354 22 Jul 2006 10:00:32 UTC 22 Jul 2006 14:34:20 UTC Over Success Done 10,498.86 130.93 130.93
    29492046 25310342 21 Jul 2006 21:19:26 UTC 22 Jul 2006 2:24:22 UTC Over Success Done 10,567.25 131.78 131.78
    29481912 25299991 21 Jul 2006 19:40:20 UTC 22 Jul 2006 0:18:38 UTC Over Success Done 11,089.95 138.30 138.30
    29461418 25281520 21 Jul 2006 16:29:11 UTC 21 Jul 2006 16:34:02 UTC Over Client error Compute error 192.59 2.40 ---
    29455184 25259340 21 Jul 2006 15:28:14 UTC 21 Jul 2006 16:29:11 UTC Over Client error Compute error 630.91 7.87 ---
    29454562 25275176 21 Jul 2006 15:23:23 UTC 21 Jul 2006 15:28:14 UTC Over Client error Compute error 165.08 2.06 ---
    29454276 25274893 21 Jul 2006 15:19:11 UTC 21 Jul 2006 15:23:23 UTC Over Client error Compute error 10.69 0.13 ---
    29453443 25274121 21 Jul 2006 15:10:34 UTC 21 Jul 2006 15:19:11 UTC Over Client error Compute error 376.33 4.69 ---
    29447640 24343770 21 Jul 2006 14:15:36 UTC 21 Jul 2006 15:10:34 UTC Over Client error Compute error 360.02 4.49 ---
    29429299 25251879 21 Jul 2006 11:24:21 UTC 21 Jul 2006 15:04:03 UTC Over Client error Compute error 7,896.38 98.47 ---
    29410789 25234665 21 Jul 2006 8:30:27 UTC 21 Jul 2006 12:50:26 UTC Over Success Done 10,316.28 128.65 128.65
    29393377 25218605 21 Jul 2006 5:42:26 UTC 21 Jul 2006 9:57:09 UTC Over Success Done 10,396.67 129.65 129.65
    29374610 25200824 21 Jul 2006 2:28:53 UTC 21 Jul 2006 7:03:32 UTC Over Success Done 10,173.77 126.88 126.88
    29356629 25184009 20 Jul 2006 23:23:37 UTC 21 Jul 2006 3:51:04 UTC Over Success Done 9,885.89 123.28 123.28
    While normaly i run without any errors, just like today ...
    - Schmetterling
    Sep 2004
    0
    Quote Originally Posted by Schmetterling
    Here, look at this:
    - Schmetterling
    Errors are fixed now
    Wondering if this benchmark is as it should be:
    1997 floating point MIPS (Whetstone) per CPU
    3239 integer MIPS (Dhrystone) per CPU
    ..for 4ghz celly, 1024mb ram ddr2-600 4447 ?
    Perkam
    Mr. Boardburner Martijn's Avatar
    Jun 2005
    the Netherlands
    3
    Quote Originally Posted by perkam
    Perkam
    That seems very low, my overclocked P3 1Ghz (1.4) scores almost as high as that...
    Main rig:
    CPU: I7 920C0 @ 3.6Ghz (180*20)
    Mobo: DFI UT X58 T3eH8
    RAM: 12GB OCZ DDR3-1600 Platinum
    GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
    Intel X25-M G2 80GB, 12TB storage
    PSU/Case: Corsair AX850, Silverstone TJ07
    Mar 2006
    0
    Perkam
    My brothers celly @ 2.26Ghz:
    Measured floating point speed 2403.12 million ops/sec
    Measured integer speed 7816.53 million ops/sec
    So they seem to be extremely low. Are you running the optimisations?
    - Schmetterling
    Sep 2004
    0
    - Schmetterling
    Optimizations ?? No clue on those.
    Link me or if people want they can pm me these optimizations...i intend to crunch a tad bit more regularly
    Perkam
    Jun 2005
    In Bed
    0
    Ok thats it your banned use the search function Here ya go link
    Sep 2004
    0
    Quote Originally Posted by njkid32
    I have Win 2000 SP4...none of those work
    Perkam
    OC Jedi (on stand-by) Fr3ak's Avatar
    Jan 2005
    Berlin, Germany
    8
    What did you smoke perkam?
    Simply get the BOINC_5.5.0_SSE2_A64_P4.zip in the optimisations folder, unzip them to your boinc folder (while Boinc is shut off) and enjoy.
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
    Sep 2004
    0
    Quote Originally Posted by Fr3ak
    Well, before I got the new cooler, I was inhaling fumes from my pressy celly :p lol
    kk, lemme see the difference it makes.
    EDIT
    7/23/2006 12:19:20 PM|| 4404 floating point MIPS (Whetstone) per CPU
    7/23/2006 12:19:20 PM|| 14077 integer MIPS (Dhrystone) per CPU
    Anyone know what my daily should be at those settings ?
    Perkam
    Xtreme Cruncher
    Jan 2006
    Cornwall, UK
    0
    The optimizations should make a large difference thanks to the amd biased standard boinc and you should be close if not higher than 5000/15000 with a 4ghz celery.
    Jun 2005
    the Netherlands
    3
    You should really try installing nn_step's crunching os, win XP or server 2003. I think that'll improve your scores even more.
    Main rig:
