My avatar
I have a sweet avatar I think you guys are missing out on - but its 159,164 bytes. Perhaps you moderators should up the file-size limit
Post it, and I'll resize it.
Here, I gave it a shot... any good?
I appreciate the effort, but the file has to be smaller than 50,000 bytes - therefore, we should simply raise the limit to 160,000 bytes, this way everyone, (ie. me), is happy
eh... wow.. I didnt know jbell put it that low.. LoL.. ok... Ill see if I can do better... Odds are Smiz will get it that low and still lookin that good before I will be able to.
Sorry bout that!~!
Originally posted by JBELL
*adds to ''to do '' list
Wh00t!
No way. I can't drop it to 50k and still keep it looking good.
Example:
This is 109k and it looks like crap. There's just too many things happening in it to cut it down that low.
try again file size is now 225k
Ok.
Sweet Action! All bow to my avatar!
your welcome
*looks at crowd*
ok who was next in line?
Okay, well I need a new Avatar - apparently mine was a little too big for some peoples connections/computation power Anyone with artistic talent that would be willing to share the wealth?
What are you looking for?
i personally would like to see nep keep his avatar but the size is an issue.... for at least one laptop user - and yes it is a P4
can you resize it smiz? make it smaller but keep quality? say around 150k?
I dropped it under 150k myself.
post so we can see it...
its the one in my post above... but here it is
Yup. IFMU beat me to it. I got it lower, but had to kill the picture quality. On the other hand, you can reduce the amount of frames, but that will make it move faster and be a bit choppy.
This one is only 113k, so hopefully it won't cause any trouble.
Thx guyz
- You may not post replies
- You may not edit your posts
Forum Rules
