Im starting to bench my pieced together PM rig and my x850xt.
Simply I just want to know how to set LOD.
Ive tried looking for it in ATi Tool and ATi Tray Tools, but I cant seem to find it.
Any help would be greatly appreciated.
in ati tool choose settings then go to driver tweaks. but the default lod is all you should use for benching. lowering it is cheating yourself
QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
DFI LP LT X-38 T2R
2X HD4850's water cooled , volt modded
Thermaltake 1KW Psu
4x Seagate 250GB in RAID 0
8GB crucial ballistix ram
Atitool (doenst work in win2k):
Ati tray tool (does work in win2k):
Well I understand that, but everybody talks about it on here and I was generally curious on where it was because I looked and couldnt find it.
Thanks though for the screenies.
Just another tweak, everybody can use it...
You're kidding, right? How do you think all these world records are done? Of course they all use it, it is just a matter of who admits it.Originally Posted by jimmyz
Originally Posted by b1lk1
[Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
[Review] ASUS HD4870X2 TOP » Here!! « .....[Review] EVGA 750i SLi FTW » Here!! «
[Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
[Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
We've been having the LOD argument since 2002 on this forum. It is not cheating per se as FM do not class it as such, however, although it is legally Ok peoples morals tend to guide them in such and you have two polarised camps on their use.
Now that Ati can do LOD it is better because when it was just nvidia it did not allow a very level playing field at the very top.
Regards
Andy
Please forgive the noob question, but what exactly is LOD?
E4300 @ 3.2ghz, 2x1GB Crucial PC-8500, Gigabyte EP45-UD3P, 4850 X-Fire, OCZ Powerstream 520.
Originally Posted by Lando95
Level of Detail.
reduces detail(if you go into the positive values) to increase benchmark scores.
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
Nvidia benefits much more from LOD than ATI though. ATI seems to perform worse at times with a higher LOD setting. The only thing that really gets a huge boost from LOD is 3dmark01.
Do you think Nvidia would be anywhere near the top10 in the orb without LOD?
Use LOD5 in 2001 with ATI
Vmods - what can possibly go wrong? ©
Yes because nvidia also tails off with higher LOD as well. When it comes down to it software tweaks will only gain you so much and it is having the hardware + cooling + vmods which always make the big difference.Originally Posted by ahmad
Regards
Andy
Is that -5 or +5?Originally Posted by ceemic
play around with it as there isn't a set optimum value.Originally Posted by filmbot
ATI doesnt just level off in terms of performance, performance is actually worse than not using LOD if its not right. Its odd I know, but who knows.Originally Posted by zakelwe
D Low and High - LOD 5
CL - LOD 2
CH - LOD 5
L Low and High - LOD 3.5
N - LOD 4
Careful, lowering or increasind LOD in 3DMark 2k1 it's a bad idea.
Thanks a lot for the help.
Hopefully learning how to play with this will help my scores get that much better since Im only on air atm.
