Results 1 to 12 of 12
Thread: Ultrasonic water foggers, DIY? How do they work??
    Mar 2006
    How do those ultrasonic pond fountain humidifier fogger things work? I have an idea thats real complicated to do with heatpipes and i dont feel like trying to explain it because i havent got it figures out yet myself I need to build myself a real high powered one...
    p.s. mods feel free to move this becuase i had no idea where to put it.
    The Blue Dolphin
    Nov 2004
    The Netherlands
    I think you need a special membrane that vibrates xtremely fast.
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Xtreme Cruncher
    Nov 2005
    Rhode Island
    Quote Originally Posted by alexio
    Its the same thing used in those "cold steam" humidifiers
    Fold for XS!
    You know you want to
    Xtreme Cruncher
    Feb 2006
    Emmaus, PA, US
    i have a couple of those lying around, just a small piezoelectric disc that vibrates at ultrasonic frequencies, it essentially vibrates so fast it vaporizes the water without heating it
    |Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
    (12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
    (12:16:19 AM) OC3D NoL: RAWRRRR
    Steak for Breakfast
    Dec 2005
    N.Vancouver, BC, Canada
    wow I never thought of that!! Man if they weren't $40 a piece I'd actually give it a try
    Though the stuff isn't condensing, it's just tiny water particles not vapor.
    Nov 2005
    Chile
    Quote Originally Posted by Thrilla
    isnt that the same thing?
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Quote Originally Posted by DeToNaToR.cl
    No, I think not. Vapor consists of loose H20 molecules flying arround. I think this thing blows xtremely tiny droplets of water in the air. It looks like vapor that's at the point of condensing.
    I'm not sure though.
    Blue Reviews:
    Blue Guides:
    Steak for Breakfast
    Dec 2005
    Liquid water particles are still liquid but divided to very tiny pieces so they're very light and "flows" in air.
    Vapor is gasous and are equal or above water's boiling point, it actually feels dry when kept above the boiling point.
    When liquid water "condenses" (gets together) it becomes water droplets, does not suck heat.
    When vapor condenses, it sucks heat and cools down to water droplets.
    Mar 2006
    so i get a pezio and drive it with 2mhz thing??
    Sep 2005
    Russia, Moscow
    why do u need it? whats the point of using it?
    Xtreme Cruncher
    Feb 2006
    Emmaus, PA, US
    check ebay, you can get them for less than $20 if you look
    Mar 2006
    I want a real big ne so i can make water evaporator so it gets cold basicly, or some other liquid.
