Page 1 of 3 123 LastLast
Results 1 to 25 of 58
Thread: Who Makes the Best Power Supply?
    Jun 2002
    usa,va.
    well after i have been through countless power supplies.
    overclocking these AMD"S is tough on a power supply.
    I want to get some oppions on the best power suppy made.
    I ordered a new PC POWER & COOLING 510 watt unit with custom built with remote adjustments on all the supply lines.
    i have been running 550 antec's but they have disappointed me latley.
    so what do you guys think are the best supplies out there?
    Feb 2003
    Norway
    hmm ive heard alot of good reviews/comments about antec true power series,i just orderd 1 of those my self a few days ago hehe,what problems did u have with urs?
    Oct 2002
    PC Power & Cooling is probably considered the best but they cost- you get what u pay for. The TTGI 520 is what many people use and it has the adjustable pot.
    Jun 2002
    usa,va.
    well i like the supply but on a epox 8rda and a r9700 the 12volt side is pulled to the max on mine.11.82 tops on 12v side measured at the molex connector.but i have this problem with a barton running 2712mhz @1.975 in bios 2.05 actual measured on the board.and a raddy running 480core.this combination kills my 12v side.
    and i ran alot of power supplys.i have 2 500watt.1 600watt and a 550 true power.where one has a good 12v it loses the 5v or i lose 3v side.the antec was the best of the 4 where the seperate circuits for the 3 voltages does help.the antec helped me get from 459core on my raddy to 480 just by changing to a antec...no joke.
    but i dont like the low 12v.so i called PC POWER & COOLING and they are custom building me a power supply.but yes it is expensive.over $300 shipped to me.
    Oct 2002
    I custom ordered a PC Power & Cooling 510W 2 weeks ago, and it totally rocks. I also had the 3 external pots put on it.
    You won't believe the quality of the potentiometers they use, such fine adjustment, they are not cheap piano pots at all.
    Voltages on all the rails are as steady as a rock...510 watts with 650 watts peak power. The important thing is that they have 40 watts amperage on the +5 and 34 amps on the +12 line - plus line conditioning, etc, etc, etc.
    If it makes you feel any better I paid around 290 bucks for mine, which was over 3 times what I paid for my Antec P412X...but trust me there is no comparison to the quality of the build. I really like how overbuilt they are. Bob Roark, their GM at PC Power and Cooling, was a great guy to work with. Tony (RoydRage) really likes his 510W PSU from them also and he recommended them to me, I bugged him about the external pots.
    One thing, the pots have very long wires and if you want to custom install into your case, be prepared to do some drilling!
    Have fun...and thanks for the help you've been giving me lately too.
    Jun 2002
    usa,va.
    yea i dealt with cindy she was nice and she went to the GM, Bob Roark and he told her he was doing a few of these as custom jobs.yes mine was $290 plus shipping.
    no problem on the help .anytime..
    i appreciate the input makes me feal better about spending that much on a power supply.
    Feb 2003
    I heard the verax FSP300 is really good quality, i really dunno where to buy one tho :/
    xp1700 @ 2424mhz | 512ddr @ 3/2/2/2 | GF4 4200 @ 320/600 | SLK800
    15093 3D 2001 Marks
    Jun 2002
    usa,va.
    WxChaser
    how long did it take for you to get your's built?
    Unoriginal Macho Energy
    Dec 2002
    PCP&C is by far the best supply out there. I got one used from a forum member about a year ago, Turbo Cool 450W. Solid as a rock. You may want to do a fan swap... The fans in these PSU's are LOUD, like 48dBa I slapped a 36CFM 30dBa sunon Sleeve bearing fan in mine and now it is nice and quiet.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Jun 2002
    Maryland
    How do you custom order a power supply? I think I might get a new one soon, looking for 550W+. What should I look for in a power supply? I'm pretty sure my next PSU will be a PC Power and Cooling one... If I can save up enough money.
    Antec TrueBlue 480
    Intel Core 2 Duo E6600
    Asus P5N32-E SLI
    ATI x1950xt 512MB PCI-E
    2x2GB G-Skill PC6400 DDR2
    2x74GB Western Digital Raptors in RAID 0
    2x36GB Western Digital Raptors in RAID 0
    Plextor 8X DVD Writer
    Sennheiser PC150 Headphones
    Jun 2002
    usa,va.
    well you have to phone call PC POWER and they will build it to you specs for a charge. it cost me $90 more to have external pots and completely load tested.will come with voltages set to 12.5v and 5.2v for me and i can adjust to the board i am using.
    Jun 2002
    Maryland
    Well, I don't know very much about PSUs, what are the main things I should look at when deciding on a PSU? What exactly are the pots for? How much would you say for a 550W+ PSU with 12.4v and 5.2v and external pots?
    Antec TrueBlue 480
    Asus P5N32-E SLI
    Jan 2003
    Gurnee, Illinois
    TTGI Makes a damn nice PSU for the cost. The 550w or the 420. They both can have their rails adjusted via a pot. Very nice PSU for the cost.
    Currently building my i7 920 rig
    i7 920 - Gigabyte x58-UD3R - 6GB Corsair DDR 1600
    GTX285 - Intel X25-M + 1.2TB - Watercooled
    Oct 2002
    Doylestown, OH
    Pots are to adjust the 12v/5v and occasionally 3.3v line. Many PSU's simply put a fixed resistor in their line, and therefore to adjust the rails you have to solder in your own Pot.
    A few companies put variables in place of fixed, and these are what most of us go for. TTGI makes a great PSU for the price, and it has internal pots. Alot of the Folders use a PSU, I forget who makes it, but it is low wattage, around $30, and has pots. PCPC is the ultimate PSU, and normally has pots on all 3 rails, but you can order the pots put externally, which saves alot of time.
    If you can through down the $Bones$, get a PCPC.
    GO for a TTGI if not.
    Antecs and Enermaxes are good, but you need to install VR's to get anything out of em.
    Oct 2002
    Doylestown, OH
    Link
    Anything with a TT is a TTGI.
    Feb 2003
    Maryland
    Well I got yet another Antec 550W from newegg, had to rma the first one. Now my 12 v rail is looking great. My voltages on 3.3 though are very low at 2.75. I have had on lockups in anything though. My voltages are right now
    +3.3 is 2.75
    +5.0 is 5.0
    +12.0 is either 11.98 or 12.04
    I'm not going ot worry about 3.3 if it doesn't LOCK UP but right now seems to be runnig good, only had it running for 3 hours now too so we'll see if it goes up with a day or two.
    AMD Barton 2500+ @ 3200+ (2.2ghz)
    Abit NF7-s v2.0
    1gb // OCZ PC-3500 El DDr
    Sapphire ATi Radeon 9800Pro (4.7s) @ 407/720
    WD800JB x2
    Audigy-2
    Antec Truepower 550w
    Oct 2002
    London
    I3lackCoffee
    If you are using Motherboard monitor to check your voltages then that 3.3 reading is actually your vdimm, NOT your 3.3v rail.
    So...you have a good supply there.
  18. #18
    Oct 2002
    Doylestown, OH
    Yeah, that is your Vdimm, if that were your 3.3, your vid card would be starving right now.
  19. #19
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    My 510w turbocool came, and UNF. That's what I say :P I got it all set up for 5.3v, 12.4v, and 3.4v. Love it!!!!!!! And this thing is built like a TANK.
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
  20. #20
    Sep 2002
    Nottingham, England
    I've heard some good reviews of the Hyper/TTGI 420 and 550 PSU's. I personally am using a Q-Tec 550w which is good enough for my system
    "There is only one thing better than having a linebacker in your office, and thats having two linebackers in your office"
    12.7Ghz folding for XtremeSystems
  21. #21
    Member
    Dec 2002
    Leics UK
    Ive always done well with fortron source units, currently using a Sparkle 400watt.
    ive heard good things about TTGI and PC power and cooling.
    I have seen several Q-Tech units at work, and ive found them to be some of the VERY worst units ive ever used (no offence gobbo)
  22. #22
    Xtreme Folder
    Nov 2002
    BFE, MI
    I have a 350w PC P&C it may not be 550w or have adjustable rails but man its built like a tank and my volts are rock solid... no lock ups and I have my system OC'ed pretty high... I paid less then $80 I could have had an Antec or TTGI 500w but I trust PC P&C... The last PSU I got from them is still running solid after 3+ years and two system upgrades...
  23. #23
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I've been through a bunch, PC Power & cooling all the way !
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
  24. #24
    Nov 2002
    Earth: The Insane Asylum of the Universe
    What do you guys think about HEC (Heroichi Electronic Corp.) ? I've only heard good things about them before, and I had a 350 watt before that seemed fine. I saw a 525 watt HEC newegg refurb for $59 today, and snatched it up.
  25. #25
    Oct 2002
    It took them about one week to produce the custom PSU for me then about 3 days shipping time (well worth the wait). By far the best power supply I've ever owned.
