Simple as that. How much CFM is one m3/h?
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
1 m3/h = 0.5885745 CFM![]()
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
Thnx a lot m8!![]()
Project ZEUS II
Watercooling setup:
ur from greece :O
Try this handy, free utility in the future: http://joshmadison.net/software/convert/
< asus p5w dh deluxe, intel e6600 es, bbati x800pro, 2gb mushkin xp2-5300, seasonic s12-600
< heatware
Lian Li V2000+ Modded
Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
Asus Rampage Extreme 2
OCZ 3x2GB DDR3 1600 Platinum
EVGA GTX460 768MB 850/1700/2100Mhz SLi
EVGA 8800GT SSC 730/1800/2000Mhz
Corsair HX850W
Yes i am. Is it a suprise...?Originally Posted by HappyUser
Project ZEUS II
Watercooling setup:
