+ Reply to Thread
Results 1 to 9 of 9
Thread: Where to find small heatsinks?
    Xtreme Member Foxie3a's Avatar
    Aug 2004
    Modesto, CA
    0
    When I say small, I mean the sizes of things like the Promise IDE controllers on a mobo, or something like the Winbond Super I/O chips on our mobos. I guess a ramsink would fit, but it's awfully tall and definitely could interfere with a PCI card, it's not something u would want stuck on there forever.
    I suppose a very short ramsink would be nice too for the intel ethernet controller on some motherboards that is in front of the AGP/PCI-E slot.
    Also, the only heatsinks I can find that properly fit on an SB are the ones made for Vantec, but they have so little metal, I would prefer something thicker, with real fins, but not necessarily tall ones. They still have to be very short so not to interfere with the PCI slots.
    I've looked for heatsinks on ebay, but there really aren't very many. The ones they have on there aren't made for the motherboard chips, they're often too wide.
    I figure I won't get many replies, but I'm just curious if someone knows of something that I don't.
    Thanks for the help in advance.
    Xtreme Enthusiast qdemn7's Avatar
    Feb 2005
    Smurf in My Loop
    0
    Check out the Micro Cool heatsinks Sidewinder sells. Will those do? The Micro Sinks are pretty small.
    MSI Big Bang XPower
    Core i7 930 @ 3.38 Ghz
    6 x 2GB Patriot DDR3 1600
    XFX Double D 7850
    Therltake Toughpower 1200
    Thermalright Ultra 120 Extreme
    OCZ Revodrive 3 120GB
    Corsair 700D
    Dell 2405FPW
    W7 Pro 64 bit
    Banned
    Jul 2004
    Scotland
    0
    Correct the small vantec cooper one from iceberg kits fits SB, i know its too small for high Oc so I cut up a gold Zalman alu passive NB cooler and use the taller Blue alu one on my NB.
    This kinda idea you want ? :
    http://www.coolestpc.co.uk/acatalog/Other_Cooling.html
    look down page at Microcool sinks
    Xtreme Addict J-Mag's Avatar
    Jan 2005
    Bay Area, CA
    0
    I have scavenged passive sinks from older video cards... Sometimes people sell lots of "untested" video card son ebay for cheap.
    Aug 2004
    Modesto, CA
    0
    The two links have a lot of nice stuff. The smaller than ramsinks heatsinks would work well for some of the chips.
    However, I still don't see anything that would fit a southbridge without taking out the dremel, which is a pain.
    I have a TNT2 32mb that had a really thick aluminum heatsink on it. It had very thick, and low fins. As an experiment I ripped it off and put on the heatsink from my IC7-Max3 when I put the NB-1 on that. The heatsink will work great for an SB. Maybe I'll look into buying a group of untested ones with those heatsinks.
    Banned
    Jul 2004
    Scotland
    0
    Foxie, There IS one meant for SB in them urls :
    Microcool South Sink - Silver or Black
    Dimensions of Southsink dissipator: 30(L)x30(W)x30(H) mm ????????
    Is that near enough for you, I know it differs slightly from the vantec iceberg kits small sink.
    Xtreme Enthusiast Reefa_Madness's Avatar
    Jul 2004
    Saint Johns, FL
    13
    Perhaps one of these might work for you.
    http://www.allelectronics.com/cgi-bi...eat_Sinks.html
    They usually carry a larger selection than what is currently showing. I don't know if they are just short on stock or if they are phasing out this line of products.
    In memory of Gracie, my sweet, sweet wife and mother of my children. Darling, we will miss you dearly. May you rest in peace (born to this world on March 30, 1976; went to her Heavenly Father on Good Friday, April 22, 2011).
    http://animoto.com/play/E0wFhd6tN0nA...ent=challenger
    Heat
    Aug 2004
    Modesto, CA
    0
    Quote Originally Posted by humeyboy
    I have one of those, but the problem is that it is so tall that it interferes with any PCI cards u might have.
    Now this on the other hand looks better, but I'm thinking it still might be too tall.
    http://www.allelectronics.com/cgi-bi...HEATSINK_.html
    In a case like this where there isn't too much heat being generated, do u think that having a thick base would be better than having long fins? Most of the short sinks I've seen have a very thin base, and a mild array of thin fins. I have yet to see a thick base with short dense fins.
    I'm seeing really nice heatsinks though, I'll have to buy them and try them out on different chips.
+ Reply to Thread
