i just bought mine... will be doing before and after temps
Asus P5B-Deluxe 0614
Conroe E6400 @ 2.56ghz
Team Xtreem DDR2 2x1GB @ 900
ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
Hitachi 80gb | Hitachi 80gb | Seagate 320gb
Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
Corsair Hx620
Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
I got mine here:Originally Posted by nealh
http://www.frozencpu.com/thr-26.html
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
wow..kinda pricey..will it really lower temps several C more than AS5
Thanks for the links guys..performance-pc is in fl ..so I get tax too..
Frozen cpu is better choice...may buy some for Sh*ts& Grins and see what happens
can you spread this with a fine modeling paint brush?
My Heat
i5 2500k @4.5ghz Raystorm
Asus P8Z68-V Pro/Gen3 16gb(4x4) G.Skill PC12800 Ripjaws X
x1900xt MCW60
Rad: Thermochill PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
Corsair 120gb Force GT SSD/ 1TB WD Black Caviar SATA
X-Fi music/SH-203B/H62L/LH-20A1L
Corsair HX620w /Acer AL2223W/modded TJ07
Yep it is pricey, however when you see how far this stuff spreads it will really clear up the price issue. IMO, with the seringe they send out you'd be good for 300 core mounts if not more.Originally Posted by nealh
The stuff is really unique in that once you place it on the core, it really seems like it won't spread, but once you break the bubble(so tp speak) it spreads and spreads and spreads for what seems like forever and it makes your tiny drop seem like much more than necessary.
I can't compare to AS5 because I ran AS3 and it had not set yet on my first mount it gave me 10c under load over my fresh AS3, then I remounted with a thinner layer and put a little more tension on my Storm waterblock and it gained me 3c more under load so a totaly of 13c overall on my AS3 application.
I do agree though that my AS3 mount was not very good. it was on the IHS, probably to thick and had not cured. So take it with a grain of salt. I am reading though, that people have seen 3 - 5c improvements consistently. I think the main reason they see the improvements is that the stuff spreads so nicely and probably maximized the contact with much less effort than the usual AS products.
Step aside, and you won't have to feel the awesome wrath of my mustache!
