this may sound dumb, but which bios should I flash to my ultra-d modded to SLI mobo? either the SLI or ultra-d bios? and which would you guys suggest by looking at my setup (in my sig)? I feel stupid lol
3200+ (looking for nice opty or 4400+) stock clocks :: Ocz gold 2x1GB ddr500 @ 250mhz
BFG 7900gtx OC stock (saving for another):: dfi lanparty ultra-d modded to SLI
OCZ modstream 520W :: 160gb WD IDE
They're all the same. Any BIOS. I run 6-23 on mine.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
Use the one youre using (depending on your memory).
Do you already got a SLI bridge?
ATM, i'm running the last one found on the DFI's website, tried it, my OC wasn't affected so i stayed with it! (yes the MoBo is SLI moded!)
