+ Reply to Thread
Results 1 to 12 of 12
Thread: Asus P5W DH + Vapochil LS
    Apr 2005
    0
    Just wondering if anyone has tried to fit a Vapochil LS to a P5W DH and experienced any fitting problems around the CPU socket. I am looking to upgrade to a Core 2 and this board but want to confirm there is no issues with a Vapo LS
    Cheers
    Administrator sierra_bound's Avatar
    Dec 2003
    Northern California
    0
    Do you have the S775 clamshell? If not, you'll need to get it. The S939/S478 clamshell won't work. I just got an Asus P5W DH and will probably test with Vapochill, though not today. Just looking at the socket area, it should fit with no problems. The S775 clamshell fit on the Bad Axe board which has a lot more capacitors near the socket.
    Xtreme Addict Dynasty's Avatar
    Jun 2004
    0
    Quote Originally Posted by Aurhinius
    Cheers
    I have not tired yet with my LS, but with my Chilly1 dual head
    I needed to surgically cut some of my arma as the caps to the right obstruct
    my insulation and create air pockets. But, it is better for mounting then
    my Bad Axe.
    May 2006
    Harrisonburg, VA
    0
    Quote Originally Posted by sierra_bound
    Where did you buy the Asus P5W DH?
    Xtreme Addict vapb400's Avatar
    Jan 2005
    Northern VA
    0
    XS user CornerJack has a modded VapoLS on a P5W DH, PM him maybe he has some info on mounting and such.
    Dec 2003
    Northern California
    0
    Quote Originally Posted by David9799
    Friend sent it to me from overseas.
    The Vapochill does NOT need to be modded to work. The S775 clamshell is very small and fits around the socket. Trust me, it will work.
    Apr 2005
    0
    thanks folks, I haven't yet got the 775 clamshell but knew I would have to get one just trying to get everything in place as it is a major upgrade. Board, memory, CPU etc.
    Want to get everything in place and some feedback before I part with my hard earned.
    plus I haven't had an intel board in ages... I thought about waiting for the intel nvidia board but who knows.
    Dec 2003
    Northern California
    0
    Here is a pic of the Vapochill S775 clamshell on my Bad Axe board. There are a lot of caps where those blue heatsinks are. Still, it fits. The Asus board has a lot more room around the socket than the Bad Axe.
    Xtreme Addict theteamaqua's Avatar
    May 2006
    Herbert's House in Family Guy
    0
    lol how many times have u explain that??
    oh and u can get it in frozencpu.com, both the clamshell, or the Vapochill LS LGA775 version
    E6600 @ 3.6
    IN9 32x MAX
    EVGA 8800Ultra
    750W
    Dec 2003
    Northern California
    0
    People used to AMD see all those caps near the socket and freak out. They think there's no way a heatsink or evaporator head will fit. The companies that design heatsinks and evaporator heads obviously thought it out so that their products will work on just about any board.
    xtreme energy kiwi's Avatar
    Oct 2004
    Europe, Latvia
    0
    s939/478 clamsheel will fit with some modding.
    Another type of screws and a bit cutting of clamshell itself because of close caps.
    It is not a good idea for long term though
    Dec 2003
    Northern California
    0
    It's not worth the trouble, IMO, unless you are good at and enjoy modding. The biggest problem is the mounting holes which are spaced differently on S775 boards. The other problem is fitting insulation between the socket and the capacitors. You can use Armaflex, but the insulation that comes with the Vapochill kit is pretty good, as long as you can squeeze it between the socket and the caps.
+ Reply to Thread
