+ Reply to Thread
Results 1 to 9 of 9
Thread: How to mount a rheobus on top of the case?
    Jun 2006
    0
    The question says it all. I want to mount one on top of the case. I am going to mod a case for watercooling and I wanted to put it next to the rad on top. Check out the other thread, it talks about that.
    Thanks.
    DFI LanpartyUT nF4 Ultra-D (BIOS 06/23/2005)
    X2 3800+ @2500 1.39 vcore
    2x G.skill 1gb Black Sticks
    Gigabyte 7900gt @ 500, 1500
    EVGA 7900gt @ 500, 1500
    SoundBlaster Audigy 2zs
    Samsung SpinPoint 120gb
    NEC Black 3540 DVR+/-RW
    Enermax 535W
    Laing D5
    MP-05 SP LE
    Maze 4 Acetals
    Black ICE GT 3x120mm
    Yates and Nexus Fans
    XS_THE_MACHINE ReD.SkY's Avatar
    Jan 2006
    USA/California/Sacramento
    0
    cut a hole and make a mounting bracket
    Asus P5B-Deluxe 0614
    Conroe E6400 @ 2.56ghz
    Team Xtreem DDR2 2x1GB @ 900
    ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
    Hitachi 80gb | Hitachi 80gb | Seagate 320gb
    Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
    Corsair Hx620
    Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
    Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
    Jun 2006
    0
    Can I just drill a holes in the top for the knobs and screw the bracket into the case?
    Enermax 535W
    Laing D5
    MP-05 SP LE
    Maze 4 Acetals
    Jan 2006
    0
    yup, even just holes for the knobs and then glue it to the case
    Corsair Hx620
    Banned
    Oct 2005
    0
    Ahhhhhhhhhh get out of my head damint!!!!!!!!!!!!!! I was debating doing similar as I would not have to run the wires as far for the fans on the RAD/Case. or second RAd if I use one.
    Jun 2006
    0
    Cool. Thanks. The glue is perfect.
    Enermax 535W
    Laing D5
    MP-05 SP LE
    Maze 4 Acetals
    Registered User Alexisferos's Avatar
    Apr 2006
    Hellas
    0
    my hand made rheobus..
    2 rheostats, 2 new drilled holes and a lot of fun..
    as you see is easy.
    and the glued box in the roof with the pump relay.
    Xtreme Enthusiast el rolio's Avatar
    Sep 2005
    Utrecht, NL // Kingston, Jamaica
    0
    uhm there have been tons of dudes who have done it. lemme find a link for you. in any case its pretty simple. when you take it apart, you wil lsee there is locking nuts, so all you have to do is drill 8 holes in hte exact position as they were on the faceplate. 4 for hte knobs and 4 for hte leds. then put hte body thru and screw it down, then put the knobs on.
    the guy who modded all them coolermaster cases acctually has a tutorial up. here are some of his cases you can look thru, starting with an actual post showing him doin it
    http://forums.bit-tech.net/showpost....77&postcount=8
    http://forums.bit-tech.net/showthread.php?t=98636
    http://forums.bit-tech.net/showthread.php?t=83438
    yea just check out http://www.coolercases.co.uk/ which is coolmiester's homepage
    Apple Macbook Pro º 2.4GHz Intel Core 2 Duo º GeForce 8600M GT 256MB º 2GB 667MHz DDR2 º 15" TFT LED backlit display // Dell 2407WFPHC // Xbox360 // Ek + Swiftech blocks in storage
    r3vo+PC Fall_06 Build
    Spring Customer Build
    Jun 2006
    0
    THanks man.
    Enermax 535W
    Laing D5
    MP-05 SP LE
    Maze 4 Acetals
+ Reply to Thread
