    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 4 of 4
Thread: DIY Battery Back-UPS using marine battery
    I've been reading on this topic of building your own battery backup supply. I've decided to do just that, however I'm haivng a little trouble deciding on some of the parts I need. First, the inverter. I've been looking at this inverter, but I've noticed it only has two outlets. Is it safe to hook a surge protector into those outlets to create more plug-ins or would that cut the maximum power output in half, because all the power would only be on the first outlet.
    Anyone ever took on a similar project? I could definately use more information.
    Banned
    Jun 2003
    Broomfield, CO
    this just screams house fire....
    My own little world
    May 2005
    The Septic Isle
    IF you don't know enough electronics to know whether the first port will get given all the power (power is drawn, not given), then you really do not wan to to be messing with the kind of current's involved here. Voltage may not kill ya, but current will get ya every time.
    While I'm all for people trying things, you, your house and family are at risk if this goes bang.
    http://www.liebert.com
    make some great UPS's, well worth the investment. their UPStation GXT1500 is still going strong here.
    Quote Originally Posted by JF-AMD View Post
    Dual proc client systems are like sex in high school. Everyone talks about it but nobody is really doing it.
    Xtreme Recruit
    Mar 2006
    yeah as InSanCen said it seems a bit risky for wat you stand to gain. if you r determined to do it maybe you could call in the expertise of an electrician just to cheack it over to make sure all i8s well. but it would most probably be safer to jsut buy one.
    athlon 64 4000,2x1gb XMS 4000@250mhz-2.5,3,3,7,leadtek 7800gtx extreme @550/1.39 stock volts,hiper type R 520W,400gb HD's.
