+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 33
Thread: Intel CPU Cap: Copper 'N' Aluminium
    Registered User Jagz64's Avatar
    May 2006
    U.K North London
    0
    Lightbulb Intel CPU Cap: Copper 'N' Aluminium
    The Picture Below Tells A 1000 Words
    Why not use copper instead of aluminium for better heat transfer ?
    Your Views Guys
    Slayer X mike's Avatar
    Apr 2005
    Las Vegas
    2
    cause of oxidation
    Goliath:
    •Intel 3770k
    •Asus Maximus V Extreme - 0010
    •Corsair Dominator Platinum 2400C9 @ 2800 10/12/12/34 - 1t
    •Corsair Neutron GTX - SSD Raid 0
    •Areca 1880i 16X - 4GB DDR2 Cache
    •2x Corsair 1200i (napalmV5 style)
    David:
    •Gigabyte Z77X -UD3H
    •iGPU
    •Intel 3770K Overclocked
    •Corsair Dominator GTX
    •Kingston HyperX SSD 128GB RAID0
    •Corsair AX650
    Jun 2006
    0
    Xtreme Member Scarlet Infidel's Avatar
    Nov 2005
    0
    Technically aluminium pretty much always has an oxide layer, its very reactive. But that doesn't matter in these cases.
    Yes, cost is porbably a large factor along with the more negative type of oxidation, im sure there are more reasons.
    Xtreme Guru freecableguy's Avatar
    Jun 2003
    Santa Clara, CA
    0
    Quote Originally Posted by Scarlet Infidel
    WTF? Aluminum is as non-reactive as a metal comes. Besides its tin over copper. Just do what I (and others do), lap it down yourself to the copper. Better heat xfer and flatter surface.
    Intel Core i7-2600K ES (D1) @ 5.0GHz - 1.38v | ASUS Maximus IV Extreme ES
    4GB (2x2GB) Corsair DDR3-2133, 8-10-8-27 - 1.65v
    ASUS 480GTX SLI | Dell 2404FWP 24" flat-panel widescreen LCD
    Onboard Realtek sound | Logitech Z-5500 5.1 digital surround speakers
    2x WD 74GB Raptor HDDs (RAID 0) | Plextor PA-755A DVD-/+RW
    Corsair HX1000W PSU | Custom watercooled Lian-Li PC-G70B
    Xtreme Enthusiast AzraelDarkangel's Avatar
    Jun 2006
    stuck in Bloomington, IN right now
    0
    I believe I read in another forum that was discussing the Coollaboratory Liquid pro that it's not actually Aluminum, but I'm too lazy to go look it up now. However you could coat the copper to prevent oxidization. If you wanted to get fancy you could coat it with gold plating but that would start to get expensive for a very small increase in cooling. In the processor business you want to keep things as cheap as possible to compete with the other guy. You could do it with the Extreme edition chips and they would probably sell it for $200 more as a super extreme edition, lol.
    Jun 2006
    0
    Ohh...Freecableguy beat me to it. So it is copper underneath...there you go.
    Xtreme Addict Delirious's Avatar
    Apr 2005
    Maine
    0
    Quote Originally Posted by Jagz64
    Your Views Guys
    Cause the world is in a shortage of copper right now, so that would mean alot higher costs.
    The difference between genius and stupidity is that genius has limits.
    - Albert Einstein
    Nov 2005
    0
    Quote Originally Posted by freecableguy
    Aluminium is far more reactive than Copper.
    Copper is a transition metal wheras Aluminium is in group 3 or something. Normally as soon as you cut into aluminium its oxidised almost instantly. When you look at your aluminium heatsink (if you have such a thing) you are actually looking at a thin layer of aluminium oxide covering the whole thing. This stops the almunium reacting with anything else.
    I knew GCSE Chemistry had its uses... wait, this hasnt helped at all.
    Registered User pitata's Avatar
    May 2006
    Sweden
    0
    Actually alu. gets an oxid layer when in contact with air rather quickly. That thin layer of Al2 O3 (if i remember rigth) is what protects it.
    Nov 2005
    0
    Yeh, that must be right pitata because its obviously O2- and as i suspected its Al3+ so the compound is Al2 03.
    Xtreme Addict zabomb4163's Avatar
    Jul 2003
    0
    correct. however we do not use pure aluminum. there are corrosion resistant aluminum alloys. very little of the aluminum you see in the world is "pure". Not quite sure why no one else in this thread picked up on that fact. Corrosion resistant aluminum is great.
    Now to the subject of why they use this aluminum alloy to cover the copper. Oxidized copper has significantly lower conductivity than normal copper. surfacing the copper with a material that has a higher thermal conductivity than oxidized copper makes a lot of sense.
    http://www.key-to-metals.com/PrintArticle.asp?ID=14
    The un-extreme XIP cirthix's Avatar
    Jul 2004
    0
    they are and have been copper for a long time now.
    the last alu heatspreader i saw was on a k6-2
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Banned Pete's Avatar
    Apr 2006
    Portishead, Bristol, England
    0
    Coper + tin electroplated outer surface...all it is
    Slovenian OC Master zbogorgon's Avatar
    Nov 2004
    Slovenia
    0
    ISH is made of coper, not alu, 100%, the gray thing is tin electroplated nickel it does not affect cooling transfer and if not anything else, it looks beter that black marks that appear on non-coated coper.
    OC-Lab.si!!
    Memory Addict eva2000's Avatar
    Aug 2002
    Brisbane, Australia
    0
    yeah it's copper underneath, i bought hardass's old 920D it's lapped and shows a full copper IHS
    May 2006
    0
    Quote Originally Posted by Delirious
    Yes, worlds copper resources will run out in 50-100 years or so, thats why the price of copper has increased almost 500% in the last 3 years. There is a lot of copper on planet earth but the remaining ores might be too thin to mine with acceptable profit even with new technology, since it needs to be 2 kilos copper per metric ton of ore, and the average is only 33 parts per million...
  18. #18
    Xtreme X.I.P. metro.cl's Avatar
    Aug 2004
    Chile
    0
    Quote Originally Posted by ted3
    prices are up because china is demanding too much they buy 1/3 of the inventories of copper.
    we produce 1/3 if the copper the world buys
  19. #19
    May 2006
    0
    I guess that could be the real reason metro.cl, i came across some articles mentioning something about it but didnt read up on it yet.
    A bit OT: anyone have accurate meassure how how thick the Intel IHS is? I was thinking of gringding it down to at least less than half thickness on my 930 before i change from boxed cooler to XP120 later today (waiting for mr postman now). Anyone tried something similar maybe? Or anyone have any warnings about this kind of mod?
  20. #20
    Jun 2005
    Bucharest, RO
    0
    You should consider grinding down LGA's pressure plate, too, or you'll be running into contact/pressure trouble if you use a rectangular-base cooler.
    The boxed one won't mind, since it has the round tronconic copper core that would "sink" inside the plate.
    Now, will a chem grad explain why did they use nickel to plate the copper heatspreader and not silver !? I'm building short-run watercooling kits, and while the blocks are 99.98% copper, I chose to electroplate them with silver to prevent oxi.
  21. #21
    May 2006
    0
    Yah, that could be Para, i have to look at the XP120's layout first. Maybe i can grind of the cooler if it interferes with the pressureplate. Doesnt feel like i be doing it today anyway, need to go over it in my mind for a few days more since i started to plan this just yesterday (and planning is half the fun of mods anyway)
    I would also think silver would be better, and with the thickness needed it isnt a price issue. However, i vote for gold plated =) - soft, durable and a great conductor.
  22. #22
    Xtreme Addict Nazu's Avatar
    Feb 2004
    Finland
    0
    Gold? It has probably the worst thermal conduction abilities compared to aluminium, copper or silver.
    [i5 2500K, ASrock extreme3 gen3, Corsair Vengeance LP 8GB 1600MHz, Palit GTX570 Sonic Platinum, CM HAF932, Antec Truepower New 650w]
  23. #23
    Nov 2005
    0
    Yes and diamond beats silver by miles.... but now im getting ridiculous.
  24. #24
    Feb 2004
    Ireland
    0
    The IHS is made of nickel-plated copper. The nickel coating is only 1~2mm thick, so it doesn't take too much lapping to expose the copper.
    Here's my old P4 2.4b:
    P5W DH | E6600 | 2Gb Geil | 8800GTX | Audigy 2 | Enermax 500W | 2407 A04
  25. #25
    Registered User jdam's Avatar
    Jan 2006
    The Netherlands
    0
    i thought gold was the metal that disposed heat the fastest?
+ Reply to Thread
