+ Reply to Thread
Results 1 to 10 of 10
Thread: Raid 0 number of drives?
    Banned
    Sep 2005
    East Coast USA
    0
    Ok I can't seem to find a definite answer to this question. Do you have to run even numbers of drives with raid 0? I have run 2 36gig raptors for years, but would like to run four. However, until I get the forth drive can I run three. Everything I seem to see always shows 2 or 4 drives, but I just wonder if an odd number is possible.
    The 8 second kid Weedsqueezer's Avatar
    Dec 2005
    Nebraska
    0
    sure it is, I run 3, 9 gig scsi in raid 0!
    Intel 6600 @3.8 ASUS P5W DH Deluxe, 2x512 Patriot DDR2 1000
    SSD faster than your HDD
    Feb 2005
    Kalamazoo, MI
    0
    No there is nothing that says they have to be even numbers, I have run as many as 12 drives in Raid 0....I am unsure of the physical limit of the protocol, but there probably is one.
    Banned
    Sep 2005
    East Coast USA
    0
    Quote Originally Posted by RyderOCZ
    ok cool. thanks for the replies.
    Xtreme CCIE Serra's Avatar
    Dec 2004
    St. Louis, MO
    0
    I'm pretty sure you reach physical limits to RAID 0 before you reach logically-imposed limits. By that point, you've also pretty well lost your mind though because you're running at least 16 drives in RAID 0 and just assuming that none will ever fail...
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
    Feb 2005
    Kalamazoo, MI
    0
    Quote Originally Posted by Serra
    Agreed, however all data was backed up to tape daily...I was after all out speed
    Xtreme X.I.P. Cooper's Avatar
    Apr 2005
    0
    12 drives in RAID0
    Can we see some tests from this setup ?
    Xtreme Enthusiast Vric's Avatar
    May 2006
    Québec, Canada
    0
    having 12 drives, I would do a Raid5 and definitely not a Raid0... 12 drive in the same time with no redundancy, you push your luck
    Rig : Core 2 Duo E6600 | Scythe Mine | 2x 1gb OCZ PC2-6400 Platinum XTC | Asus P5B Premium Vista Edition| eVGA 8800GTS 320Mb | 1x Seagate 80gb SATA2 2x 250gb WD SATA2 SE16 Raid0 | SB X-Fi | OCZ GameXstream 600W | Silverstone TJ06 case
    Xtreme Mentor uOpt's Avatar
    Aug 2005
    Boston, MA, USA
    0
    Quote Originally Posted by cronic
    Any number allowed.
    As for raid-1, BTW, many people don't know that. If you want a real redundant system, but up two drives in your PC and hook one USB drive on a different PSU up.
    Jan 2006
    Esbjerg-Denmark
    0
    Any number of disks can run RAID 0, as long as it's 2 drives or above.
    RAID 3/5 needs at least 3 drives
    RAID 6/10/0+1 at least 4 drives
    RAID 30/50 at least 6 drives.
    Core 2 Duo E6750@stock 1.275Vcore (1.26V effective) | Asus P5B Delux WiFi AP no mod | 2*1GB Kingston HX PC2-8500 1:2 devider (DDR2-1000 @ stock timings) | WD Raptor 740 (OS) | Hitatchi T7K250 250GB SATA2 (Storage) | Club3D X1950XTX@stock with EK X1800/1900 waterblock | FSP Epsilon 700W | Stacker STC-01 cabinet | 2 Water cooling systems (one for CPU (Swiftech Storm, dual + single 120mm BIX heat exchanger and Laing DDC Ultra) ½" ID, one for the NB, GFX, Mosfets and raptor 10mm OD) | Samsung SH-S183A (Black) DVD ±RW
+ Reply to Thread
