+ Reply to Thread
Results 1 to 9 of 9
Thread: CPU limited in 3DMark 05 w/ XTX and 2.7ghz X2??
    Nov 2004
    0
    When my XTX (super badass card btw) was at 690/800 I got 12.5, and at 700/870 I only got 12580 ... CPU limitation then or???
    BTW, my memory oc was with ATI TOOL not Ati OC so the timing issue shouldnt have been the cause...
    Also... has lapping the core and/or applying AS5 really helped a lot? I cannot get passed 710 or so on the core even at 1.475 it seems even though my load temps stay at about 75c
    E6600 - 3.67ghz | 1830mhz FSB | 2x1gbTeamGroup Extreem @ DDR920 Cas4 | GigabyteDS-3 | 5x120mm Panaflo | 2xRaptor74 RAID 0 | eVGA 8800GTX - 632/2100mhz | Coming: BenQ FP241W 24.0" WS-LCD | Dell 2005FPW 20.1" | Antec P180 | 2x NEC-DVD-RW | X-Fi 7.1 | Z-680 Digi 5.1 | OCZ GameXStream 700w| Logitech G5/Saitek Eclipse
    Admin Vapor's Avatar
    Feb 2005
    Ann Arbor, MI
    1
    Too much of an OC will lower the score...work your way up
    Nov 2004
    0
    I'm sorry could you be more specific? Are you saying it hasn't been properly warmed up yet ??? I'm unfamiliar with that notion... thanks for any info
    Muslim Overclocker ahmad's Avatar
    May 2005
    Canada
    2
    If you push the RAM too far too fast you will see something like this. Keep the RAM at 800MHz, then OC core to 690 from stock, then 700 and bench again.
    My watercooling experience
    Water
    Scythe Gentle Typhoons 120mm 1850RPM
    Thermochill PA120.3 Radiator
    Enzotech Sapphire Rev.A CPU Block
    Laing DDC 3.2
    XSPC Dual Pump Reservoir
    Primochill Pro LRT Red 1/2"
    Bitspower fittings + water temp sensor
    Rig
    E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
    I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
    Nov 2004
    0
    Does that concept apply to core OC as well?
    And on a side note, do you guys think its possible ATI Tool is over-estimating the volts it sets?
    Reason I ask is, it seems to like 1.45 to be stable at 690 which is easily attainable in CCC with a supposed voltage of 1.4 or 1.425 according to madshrimps XTX OCing guide
    Nov 2004
    0
    Rephrasing, does what you're describing apply to the core and its speed also?
    Xtreme Guru IvanAndreevich's Avatar
    Dec 2003
    Vancouver, Canada
    0
    I guess it could, but I mostly got that problem with RAM speeds.
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    pepsi fiend einCe's Avatar
    Jun 2005
    La Verne, ca
    0
    you need more cpu speed. 05 doesnt get a very big boost from dual core as opposed to 06, in 05 it seems like 100mhz on cpu nets about 200 points
    Lanparty Ultra-D DEAD|REVIVED
    X2 3800+ LDBHE 0606 EPMW 2950 @ 1.55v DEAD|STILL DEAD
    Powercolor X1900XT 725/873
    dell 2005fpw 20.1''
    Quote Originally Posted by afireinside
    "uh yeah is this DFI RMA dpt? yeah I was setting up your ultra-d motherboard last night and the pwm shot a flame at me... can you give me a new one?"
    Quote Originally Posted by Mr. Popo
    if you wont eat all of your vegetables einCe will come and get you!
    Banned OBR's Avatar
    Dec 2005
    Everywhere
    0
    Dont use this OLD-STUPID benchmarks...., test in games .... or 3d06 ...
+ Reply to Thread
