Xtreme Legend
8k3a+ or KX-7
Ok I currently have an epox 8k3a+. I have heard from a lot of sources that the KX-7 performs much better. Since then I have thought about getting one. But would it be worth it or should I stay where I'm at. I mean they aren't that expensive right now. Also with all the new stuff thats fixing to come out should I wait? Also how do you do the volt-mod on the kx7.
Well that would depend on you! I have the Asus A7V333 and that is a great board, but since the Abit KX7333 is suppose to be the SH*T, I went ahead and got it. Just because everyone else is having GREAT success overclocking it as well as its performance topping all other mobos. I have done the vcore and vdimm mod to the board but have not installed it yet.
To do the vcore mod to the KX7 all you need is a 18kOhm resister. Find the Hip6301 chip on the board and soldier one end on the resister to pin 7 and the other end to pin 9, with this done you will beable to increase your vcore up to about 2.10v
Good luck on your decision...
PLAY COMPUTER
(Unlocked)AMD XP 2000+, Asus A7V333, VisionTek GeForce4 Ti 4400, 80G Maxtor ATA133 7200Rpm HD, Antec PP-510 & Antec PP-412 Psu's, 226w Peltier, Danger Den Maze 3-1 WB, ViaAqua 1300 Pump, Black Ice Extreme Radiator, 1/2 Silicone Hoses, Acer 56x CD Rom, Acer 12x8x32 Re-Writer, 1 Stick 512 Samsung Pc2700...
WORK COMPUTER
(Unlocked)AMD XP 1800+, Epox 8kha+, ATI Radeon 8500(Retail), 30G WD ATA100 7200Rpm HD, Enhance 300w PSU, Hitachi 40x DVD Rom, Lite-On 12x10x32 Re-Writer, 2 Sticks 256m Crucial Pc2100...
System Photos
- You may not post replies
- You may not edit your posts
Forum Rules
