Free time? I just played 16 hours of World of Warcraft in the past two days. Who says I've got free time?
lol
lol
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
That game is a second job YOU pay the employer to do...
Originally Posted by Nefilav
and you love it, its just like crack
French Duron Poof
Every time you lap a swiftech block a kitten dies
"Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
HEAT
Nope, I played it for a day and it was boring...only RTS/FPS for me.
With my luck I will finish the chiller and my AMD chip will be coldbugged at -2. Any progress on yours Epion?
Were does one find 1.5" copper pipe? I am not finding it local for some reason. 1" is all the bigger they go.
Got an Xtreme System? Bring it here! <----
have you checked at a place that installs water lines for houses or industry’s!! I think if you can get someone to help you at Home depot they will sell it to you as a special order item!
I don't have the patients for special order lol Have to wait till Monday to talk to supply placesOriginally Posted by littleowl
I put the parts in a old case to get windowz installed and see what the opty will do on big air (XP90c) and get every thing ready for the cold. Hope to get some more done on my 4 day weekend. Hope
finaly got my hold down drilled out and ready. Had a couple hours to play.
Here is what I got done.
on the chiller side I was thinking to make it easyer to ins. the video card would this work by running a piece of tube over the ram and pressing it down with the ins. What do you think?
pic of the evap on the mach1 upgrade. Home grown
It does look decent!! I thought it would look really bad when you told me about your idea!!!
Why not use a 6000 series water block on your gpu. But be warned. The 6000series swiftech blocks are also soldered together.
The trick to getting a solder joint that is very durable even at low temps is heating the metal up and applying solder a split second before oxides form heat form.
The main way to do it is to tint both sides of the block while heating them and let the settle a lil bit and then just put the blocks together and reheat them uniformly untill the solder melts and spills out the sides. Make shure you get a tight fit so the solder is minimalistic.
Too mutch solder creates a brittle points. Less is more in soldering.
Im no expert but this is how I perform my soldering needs.
My pc: |||Abit AL8-V||| P4 631@4.6ghz||| 4x512 PDP pc2-4200@4-4-4-12 2.0v|||1x250gb WD 16mb sata||| 6600gt 500/1000@ 610/1240||| TDK dvd burner||| watercooled cpu and gpu and custom moded case.
Project Hard Lined
I agree jaguarking but that is kind of what he is trying not to do!! He tells me that he is not worth a crap at soldering! I told him it is not that hard!!
I have enought flat bar to make one so what t F I will just make one and braze it shut. Might as well make this a looooooong build right? lol
Hope it works good too.Originally Posted by denmason
Welcome to the forums DenMason
Got a leak in the evap some were. Got to take it apart
F it I made a new one. I will mess with the other one when I have time to waist. This one better work. same design just different braze job on it.
got me a 6002 to mod for my vga and made the new evap last night. Slow but steady.
Edit:And I think I got a shaft on my 404a off ebay. paid in full on june 21st and have no gas or contact from the seller for the last 2 weeks now. I hate this crap. Why can't you just be honest or get a job? Dude has 148 pos. feedbacks and on e-bay for over 2 years. Not much of a gamble I though.
http://www.thermaltake.com/product/L...8/cl-w0088.asp
any one see this real life? is it brazed? I know I read it is but I want to know for sure before I go looking for one.
