Results 1 to 7 of 7
Thread: Intel BadAxe and X6800 Question
    May 2006
    Suppose i plan on pairing intels badaxe board rev.304 with a conroe X6800 (2.93Ghz, 11x multip, 1066fsb)...will my oc limit be the board's 30% OC limit or the proc itself?
    as far as multipliers on the XE, im aware they are unlocked both up and down, whats the highest multi?
    and if the multi could go to lets say 18 or so, that would make it easier to negate the 30% fsb limitation cause i can just increase multi...is my logic here correct?
    i appreciate all the help you guys can offer to an XS newbie
    May 2006
    Silves
    In bios you have the option to switch from the normal 1066 bus speed 266x4 to a 1333 bus speed 333x4.
    Well 333x30%= 433 bus speed.
    433 x 11= 4763mhz of cpu speed.
    I think you will be fine.
    May 2006
    thank you very much!
    Xtreme X.I.P.
    Dec 2005
    the highest multi was way over 18, it was in the 20's somewhere... I dont remember. worked great in a 304 badaxe for me.
    You have lots of FSB headroom, and the unlocked multi makes it easy.
    CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Zippy 700W (fan modded of course)
    Dec 2003
    At work
    I think the highest defined multiplier for the Core 2 Duo chips is 32x...LOTS of headroom with an XE...
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
    Git-R-Done
    May 2006
    Toronto, Canada
    Somehow I doubt x32.... lol
    Dec 2003
    At work
    Why not? Prescott has a maximum defined multiplier of 60x.
    CrystalCPUID shows 6.0x-32x multiplier range on a Merom...only usable up to the CPU's original maximum though.
