Woops, didnt even realize that. OPP & OPB, 1 letter difference.Originally Posted by M.Beier
On topic, congrats on braking 12k and I would still like to see some rosetta benchies to see if bandwith has anything to do with it.
Already did. Problem is my 7900 cards have bad memory. I need new cards to get serious.Originally Posted by M.Beier
With this Same Corsair 6400C3 running at 808MHz 3-3-3-5 1T I scored:
#3 in 3D06
#5 in 3D05
#2 in 3D03
OPP
Dont you dare tell' me you havnt done a 01SE oldboyOriginally Posted by OPPAINTER
01SE it the way we play mate, heh, at least the x850XT havnt got retired in that bench yet
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
Spectating;
2010; GOOC 2010 Many thanks to Gigabyte!
No I havn't done 01 as matter of fact. I think it I may score around 52k with single card.Originally Posted by M.Beier
OPP
wow ddr2 can finally show its true power in your hands
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
I threw my Corsair 8500C5 in along with my 6400C4 for 4 gigs of ram.
Hows this 4-way interleave action
OPP
Damn you Eric, if you dont stop soon, my keyboard will die due
Hehe, well, seems like its worth getting' another 2*1GB sticks... - Tetris requires 4GB's as well
Spectating;
Seriously.. wow. That is awesome stuff man.. keep it coming! It's great that the different modules worked together no problem.
Intel C2E QX6850 @ 3.33GHz, ASUS P5K Premium, OCZ 8GB PC2-6400, eVGA 8800GT, OCZ ModXStream 720W, Thermalright Ultra-120
Seagate 500GB, 750GB & 1TB, Samsung 20x DVD-RW, ASUS Xonar D2X, Antec P182, Ultrasone PRO 750, Dell 2408WFP, Gentoo 2008.0
"Life without knowledge is death in disguise." - H.P. Baxxter
Techgage.com Editor in Chief | Profiles: Last.fm | Xbox Live | Steam
I just tryed it at 800MHz running 1T.
1T isn't gunna work very good with 4 sticks
Didn't run at all at 800 1T.
OPP
great work OPP, AM2 is glowing during its' 15 minutes of fame.
Charlie, stop that BS...Originally Posted by charlie
AM2 might even be better in 64bit apps, seen the 64bit performance of conroe??
Would be cool to report a mod though
Spectating;
seen 64-bit performance of am2? I will guarantee you that the ratio of 32bit performance to 64 bit peformance is almost exactly the same on conroe and am2.Originally Posted by M.Beier
As i said in the other thread, it is the lack of 64-bit programming, drivers, and better OS that is giving the decreased scores.
s754/939/940 picked up performance going from 32bit to 64bit in most apps.
Conroe only gained in cinebench from what I know (and a synthetic bench that I forget the name of).
If AM2 picks up like 754/939/940 did then that gives some breathing room.
All along the watchtower the watchmen watch the eternal return.
That would be intresting to see to bad 64bit os are missing so many drivers or atleast microslows os doesOriginally Posted by STEvil
Q6600 | P35 DQ6 | 4x1GB Ballistix8500 | 8800GT 512 | PC P & P 750w | WC Mcp655, D-tek Fuzion, Maze 4, Bip3 |
E6600 | Abit AB9 QuadGT | 3x1GB D9GMH | 7900GTO | Silverstone Zeus 850W | Aircooled |
E2160 | Giga 965 Ds3 | 3x1GB D9HNL | 7600GS Silent |Seasonic s12 600w | Aircooled |
Oppainter,
what could you tell about the latency of the memory at the varoius settings?
Thank you...
Intel Core 2 Duo E8500 @ 4250 MHz (500x8.5) 1,280 Volt; Cooled by Thermalright IFX-14
Asus P5E64WS professional
Kingston HyperX PC14400 @ 1600 MHz 7-6-6-18 1T 1,92 Volt
Leadtek 8800 GTS 512 MB 800 (1970) / 2200 MHz
Hi Eric, nice to see you playin on Am2 and DDR2.
Interesting thing to see different performances with 1t/2t.
OT: have u checked recently Overclocking section and took a look at a certain Opteron 154 under s.s ?
/OT
very impressive results
Am2 in your hands is a POWER
Corsair 6400C3 is not just for AM2. Works pretty good on Intel platform too. 440 @ 3-3-3 so far with 2.38v. I just got the modules and have tested them for less than 30 minutes. No memory tweaks. I just set main timings to 3-3-3-9 and upped FSB/memory speed. Have not tried any other settings yet. I think these sticks will do 450 @ 3-3-3, especially with something better than the AOpen board I'm using.
Originally Posted by sierra_bound
Have you played with other memory, how do these Corsair 6400C3 compare?
OPP
I have Super Talent DDR2-800 that will do 413 @ 3-3-3, so the 6400C3's are much better, at least with those timings. 3-3-3 is about as low as you're going to get with 1GB modules. I tried 3-2-2 at 400, but just got loud beeping on my board. 4-2-2 was also a no-go at that speed. I just tried 3-4-3 and got them to do 444.
Because of the FSB limitation with Yonah, I haven't been able to test the limits of the C3's. In all likelihood they will do 500+ at 4-3-3.
I still like the Super Talents. Even at 4-4-3, they are very fast.
6400C3 slightly tweaked. DDR2-880 @ 3-3-3.
DDR2-887 @ 3-4-3
That's some sweat clocks on the Corsair
Assuming it's 1T.
How many volts are you useing?
OPP
Thanks. Using 2.38v (DMM measurement). Hoping for 450 @ 3-3-3 with same voltage when I get a Conroe system.
Looks like the 6400C3 is clocking even better on Intel then it does on AM2.Originally Posted by sierra_bound
OPP
I haven't run Sandra, but I'm sure I won't get anywhere near the bandwidth that you're getting with AM2. The C3's do seem to clock well on Intel.
