What is the lowest temperature anyone has ever gotten on a cpu?
Intel E6300 1.86ghz @ 3.6ghz w/ Zalman CNPS 9500
Gigabyte IP35 DS3
Crucial Ballistix Tracer 4gb
XFX 256mb 7600GS
Seasonic S12
1.5tb hdd space
Anywhere from -100C to -192C, LN2
You can not always measure temperature, besides many MB don't report core temps
ln2 is the coolest thing i have known being used to coll a cpu whit.
i dont think any cpu can handle much more than -200 whiout die.
celeron!!
I know this, but what is the lowest temp ever recorded on a cpu?
Gigabyte IP35 DS3
XFX 256mb 7600GS
Seasonic S12
1.5tb hdd space
well do you mean on or off?![]()
Realistically it cant be far off ln2 temps with a yonah or something idling.
Vince, what's the guy in your sig holding?
Comrad, good ques... I've wondered as well... I would be more interested to know what the lowest load temp was.
ASUS Crosshair V *Water* | FX-8150 Enzotech Sapphire CPU block | 8GB Mushkin 2133 | 6970 2GB | 240GB OCZ Vertex 3 | SB X-Fi Elite Pro | Corsair 520W Modular | 3x 26" Asus VW266H Eyefinity 5760x1200 | DDC pump with petra top @ 18w, Thermochill HE 120.3 w/ 3x120x38mm Deltas 152cfm on controller |
My Heatware (1000+ flawless)
2 words... Liquid Helium. Someone with too much time and money needs to try that.
Current 24/7 settings
Delidded L628B e6400@ 3.6ghz 1.38v
3.9ghz 1.56v dual prime, 4ghz dual 32m pi stable on water and P5B Deluxe
Patriot 667 LLK @ 970 mhz 4-4-4-4 2.3v
x1900xt 690/780
it costs something like 30€ per liter:s damn
this price simply stops anyone to try it, one time for all the service(dewar renting, lhe filling, cryogenic substances manipuation, transport) they asked me around 1000€
and how cold is that?![]()
Have a nice day![]()
QX9650 ES - 1M @7,984 sec - Asus Maximus Formula SE - LN2
E6600 - 1M @9,937 sec - Asus Maximus Formula SE - LN2
E6600 - 1M @10,016 sec - LN2
E6600 @ 4100mhz AIR -1M 12,500sec
E6600 @ 4285mhz AIR validation
OCZ PC8000 @ 684mhz 5-5-5-15 1M
http://www.overklokken.info --> THE dutch overclocking website.
"Below its boiling point of 4.21 kelvins and above the lambda point of 2.1768 kelvins, the isotope helium-4 exists in a normal colorless liquid state, called helium I."Originally Posted by Extera
"Liquid helium below its lambda point begins to exhibit very unusual characteristics, in a state called helium II."
"Helium II is a superfluid, a quantum-mechanical state of matter with strange properties. For example, when it flows through even capillaries of 10-7 to 10-8 m width it has no measurable viscosity. However, when measurements were done between two moving discs, a viscosity comparable to that of gaseous helium was observed."
And, of course, the creeping effect.
Helium is so cool![]()
Intel Core 2 Duo E6600
Crucial Ballistix 2x1GB DDR2 800 4-4-4-12
Asus P5B-Deluxe
eVGA 8800GTS 320MB
74GB Raptor | 300GB Maxtor
"Naked" Opteron 165 @ 3.0GHz | 1.55v
X1800XT
27.734s 1M || 10476 3DMark 05 || 38850 3DMark 01 || 116,315 AM3
4.21 kelvins? (0 kelvin is -273 celcius right?)
OMFG now that would be the ultimate cooling!
RightOriginally Posted by Extera
Why not make it solid helium... This is XS, right?? Helium becomes solid at 1Kelvin and 26 Athmosphere, otherwise it doesn't, but who caresOriginally Posted by kiwi
Main rig:
CPU: I7 920C0 @ 3.6Ghz (180*20)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
Intel X25-M G2 80GB, 12TB storage
PSU/Case: Corsair AX850, Silverstone TJ07
Liquid Helium isn't a super-fluid ?
Edit : Helium III probably :/
Helium II is actually a superfluid, that's written above
Umm XS has Members: 28,862 so if thus happend
All coughed up $30 USD
That be $865,860
If 1L of LH costs $30
Then we can buy 28,862L exactly and probs set some amazing speeds
heheheheh
Is LH not evaporating much more faster als LN2?
At temperatures that low the electrons slow down and therefore reliable movement of them is not a given. I would say that you wouldnt be able to boot a pc at those temperatures much less get carzy OC numbers out of it.
liquid helium doesnt have much capacity
As LH approaches 0k, it becomes somewhat of a raritya frictionless liquid...
Listen to Tyrou![]()
In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
Well, here is your coldest chip!
http://news.com.com/2100-1006_3-6085...5568&subj=news
(allright, it's not a cpu)
they used Liquid Helium.
man o man, what a wet dream
I honestly don't see how a CPU would even boot at 4 Kelvin, or even 50 Kelvin... it's just way too cold... not to mention, do we even know what materials can handle that type of temperature (screws, container, gloves, etc.)?
Isn't it also so that at a certain temperature, everything gets conductive? Like plastic and rubber and all you can find on a motherboard.
...is no longer working as an assistant HVAC/R-installer...
But, is still blasting 20000 songs of real Rap
