Alright guys which one is better, or what would you pick?
Zalman Fatal1ty FS-C77
Thermalright XP-120
ThermalTake BIGTYPHOON
Thermalright XP-120
ThermalTake BIGTYPHOON fo' sure, if you do the mods...
Ed.
Conroe E6420 @ 3.3ghz at the moment.
DFI Dark P965
2gb Geil DDR800 4-4-4-12
8800GTS 512mb
1.7TB Storage
CM Stacker
what mods?Originally Posted by eddieate
lap the base and plug the holes with something, I used the foam out the packaging.
Ed.
DFI Dark P965
8800GTS 512mb
1.7TB Storage
CM Stacker
TT BT out of these 3 options. If not Noctua NU-H 12 or NU-H 9 or Tunqi Tower 120 or Scythe Ninja.
if you can find it get Thermalright SI-120 it's the updated version of the xp-120.
but newegg doesn't have it just the xp-120
http://www.newegg.com/Product/Produc...82E16835109118
Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
LSI series raid controller
SSDs: Crucial C300 256GB
Standard drives: Seagate ST32000641AS & WD 1TB black
OSes: Linux and Windows x64
Here were the results of my testing.
The Zalman7700 really doesn't perform on par with the rest of the heatsink, but it looks nice.
Given the set of circumstances (for my testing, an open test bench and a very hot cpu), the TTBT performed considerably better than the lapped xp-120.
navig
Navig's list of mod links ~ Exoframe Mini ~ Cabinet PC ~ Vertical Benching Station ~ Brass Tacks ~ Exoframe 2.0 ~ Project Vitis ~ Project Resilience ~ Very Low Cost Benching Station ~ The Exoframe Project ~ Jewel Box Project ~ DIY Benching Station ~ Console Project ~ Project Dark Side ~ Tower PC ~ Dual Tower PC ~ Bench Rig ~ My only standard case
sweet review there NavigOriginally Posted by Navig
Big Typhoon. It's very close between the BT and XP-120, but the BT has been found to be slightly better in most cases.
Abit KN8
AMD Athlon 64 X2 4400+ @ 2.6GHz
Thermalright SI-97A w/56 CFM Panaflow
2GB G.Skill DDR500 GBHZs 0603
eVGA GeForce 7600GT w/Zalman VF700-CU
Sound Blaster Audigy 2 ZS
160GB Western Digital 160GB Hard Drive
500W XG Vortec Ver. 2 PSU
NZXT Zero/Logitech MX518, X-530/Saitek Eclipse
CPU soon to be under WATER (this time I mean it)
Planned '07 upgrades: 19" widescreen LCD, mid-range DX10 card
For best value I'd say the XP90.
Big Typhoon.
Lap the base, plug the holes, and put a better fan on top of it. After that the performance approaches watercooling levels.
Intel Rig
2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
Custom Water of course
I've decided on the Big Typhoon and I will be equiping it with my 120x38mm Delta 141CFM About lapping the base, I've never really done it...... I thaught the base comes factory lapped and is as flat as you can get it????Originally Posted by Absolute_0
also where can I get a lapping kit? and what the performance increase?
The base comes flat, not factory lapped, AFAIK.
Get some sandpaper from a hardware store. 200 grit, 400 grit, 600 grit. Grind away in order until you have something pretty smooth. I used to say to go up past 1000 grit but Cathar says the best results are with ~600 grit.
Intel Rig
here you can see a heatpipe roundup:
http://www.chilehardware.cl/modules....file=200605121
the only one missing is the zalman
how much of a performance increase is there?Originally Posted by Absolute_0
from what i have heard upto 3-5 DegreesOriginally Posted by -aDaM^
Fold for XS!
You know you want to
That's insane.....Originally Posted by Lead Head
anyone know where I can find a lapping kit or tutorial? I'm pretty sure I know how to lap a base.... but I want to be 100% sure.
This guy has some of the best lapping kits around.
http://easypckits.com/
thanks houserat exactly what i was lookin for.Originally Posted by HousERaT
I've used this kit before. Excellent Kit. It is cheaper to buy the sandpaper yourself, but if one is lazy this is the Kit to useOriginally Posted by HousERaT
------------------Pushing the delta between idle and load, to the limit------------------
KoyoThread
7900GT 705/2040, DFI Ultra D AE0, Opty 146 3.10 Ghz, MP01 +MP05 . CPU: 19/21 GPU:24/28 Fan/Shround in progress..
Big Typhoon FTW. I've used the 7700AlCu and 7700Cu (same as Fatailty, except it's not red and I'm not paying royalties to some guy who plays video games because he doesn't have a real job) and the Big Typhoon killed them both. From there, the other option just isn't as good as the BT.
Serra
Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
Xtreme Network:
- Cisco 3560X-24P PoE Switch
- Cisco ASA 5505 Firewall
- Cisco 4402 Wireless LAN Controller
- Cisco 3502i Access Point
Hey Zenkirou, which grit did you start off with???Originally Posted by Zenjirou
