A more complete list for BT-37E :
D9FJG , D9DQW , D9DNZ , D9CVZ , D9CRZ
http://www.hobid.com/inventory/D/25.html
OPB are you 100% sure that D9DQT are BT-37E ? Why everyone says that they are BT-3 ?
Any results?Quote:
Originally Posted by Onepagebook
does anyone have a rough idea how fatbody D9 will scale with 4-4-4-12 and 5-5-5-12?
Trying to find my motherboard's limits first and lowest ratio is 1:1
I've got max 2.4v to use and so far at 461mhz 4-4-4-12 2.3v but not sure how much further it can go
If it's real fatbody, you could do 4-3-2 or 4-2-2 at those speeds.Quote:
Originally Posted by ArcTan
thanks but just want to see how they do with 4-4-412 and 5-5-5-12 to try and max my fsb. pretty sure they're fatbodies as they're 5400UL corsairQuote:
Originally Posted by thunderstruck!
Anybody ever heard of 4QB11 D9CHL ?
It sits on pc3200 c3 micron ram...
It's old ram btw, about 8 months old
With 2.4V and D9DQT you can get something like :Quote:
950Mhz - 4-3-2-4
960Mhz - 4-4-4-4
1060Mhz- 5-5-5-5
If you have the slower D9DQW :
920Mhz - 4-3-2-4
950Mhz - 4-4-4-4
1000Mhz- 5-5-5-5
These results are from trying more than 20 sticks of D9DQT & D9DQW .
The chips you have in your 5400UL depends on the revision . I don't remember which IC's goes with each revision though .
I wonder what my new RAM has (see sig) I don't want to take the heat spreader off and I guess that's the only way to find out.
mine are v1.2 and look like they scale to about 960 4-4-4-12 at 2.4v so it seems I may have hit my ram limit.Quote:
Originally Posted by Stelios
960 is not bad . Try with 4-3-2-4 . I get 958Mhz with this setting and its faster . 2.4V again.Quote:
thanksQuote:
I'll give that a try sometime
still trying to find my motherboard's limits as I'm still using 1:1 ratio
edit: do you know if 5400UL v1.2 are D9DQT or DQW?
5400UL v1.2 is D9DQW (BT-37E rev. A).Quote:
thanks alot :toast:Quote:
Originally Posted by The Stilt
I can't find this memory. Well I've found it, but it's terribly expensive. Am I missing something or will I have to spend a ton to get this?Quote:
I found these under my Heatspreaders:
http://pics.pajper.net/patriot-d9-fatbody.jpg
you have 2 mushkin 2x1gb sets listed in here but the model numbers you list don't exist either under extreme performance or high performance. the ddr2-8000 should be the extreme performance redline md#996525 and the ddr2-6400 extreme performance md#996523; at least as far as i can tell. would be great if you could check up on that and confirm if they are d9 chips after all :D. i'll let you know if i find anything. i'm considering buying this mem so yeah. also d9 can do 500mhz+ right?
or if anyone else could verify what chips they are ;)
subscribed...
Complete NOOOOB question here. But I don't have much time to write this so I'll check when I get back home.
Can someone give some "knowledgable" info on why D9 chips are the dogs?
I mean I was getting some G.Skill PC2-6400's, but they have no D9. Does that make them crap or something?
What cip use this memory http://geilusa.com/proddetail.asp?linenumber=71 ,and is dhis memory good?
This is my Crucial Ballistix 2x1GB DDR2 1000 4-4-4-10@2,3v prime95 blende test stable!
They aren't fat body...but they run so pretty;)
http://img188.imageshack.us/img188/6...1000444re4.jpg
Cans omeone tell me if one of this memories uses D9?
2 GB (2 pcs 1GB) DDR2 (800) PC2-6400 Patriot (PDC22G6400LLK)
2 GB (2 pcs 1GB) DDR2 (800) PC2-6400 OCZ Platinum Rev 2 (OCZ2P800R22GK)
Thanks.
Can anyone conform or deny that these Crucial Ballistix PC5400 4x 512MB dimms are or are not fatbodies?
http://gallery.weyland.be/v/Computers/hardware/Crucial/
If you need other pics, please yell :)
Hi.Is it fatbody or else(D9DBV).Any bady says this Ic o.c rate. thanks:idea:
http://img155.imageshack.us/img155/8435/ram1uv3.jpg
No these are simple D9.Fatbodies are not square(bga).I'm pretty sure that they oc fine too..
Hello!Are these [ http://www.supertalent.com/products/...?PN=T1066UX1G5 ] fatbodies? :)
